Date/Time: Fri, 27 Dec 2024 15:42:08 +0000
custom indicator
View Count: 769
[2016-04-14 18:21:26] |
User170575 - Posts: 221 |
Hi---I would like to draw a line on a chart that is equal to a moving average minus another moving average-- ---do you have a study that will do this or must I go through the custom indicator learning curve? Many thanks, Cy |
[2016-04-14 18:58:53] |
You can use the Study Subgraphs Difference study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s185 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
