Date/Time: Fri, 27 Dec 2024 16:05:11 +0000
Consecutive Bars POC
View Count: 674
[2016-04-14 15:36:16]
apollofl - Posts: 95
Support.. Anyway I can get you to program 2 or more Consecutive POC's at the same price level. Using a Horizontal Ray Tool drawing tool until the end of the session?
What would be the cost?
Date Time Of Last Edit: 2016-04-14 15:40:21
[2016-04-14 18:54:38]
We do not understand this.
And we are not able to do any custom programming like this at this time or anytime soon.
Also this sounds very complicated so it would be expensive. Hundreds of dollars.
[2016-04-14 20:50:34]
Ok Thank you for your response.
