Date/Time: Fri, 27 Dec 2024 15:57:12 +0000
order_confirm
View Count: 739
[2016-04-14 10:34:13] |
User850017 - Posts: 41 |
Hello, I dont need display this confirm. Where Can I fix that. THX |
sierra_4.jpg / V - Attached On 2016-04-14 10:34:03 UTC - Size: 269.25 KB - 252 views |
[2016-04-14 17:30:58] |
Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderConfirmations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
