Date/Time: Fri, 27 Dec 2024 16:07:12 +0000
Color Bar
View Count: 728
[2016-04-14 10:26:42]
User38606 - Posts: 108
I am using Spreadsheet Study / Alert. I have developed a study whereby I want certain bars to be coloured into 2 different colours. The study populates two columns with either TRUE or space. This is formula driven result. I have chosen columns P and O to be populated with either TRUE or space. When Column P has TRUE, then colour the bar Blue. when Column O has True then colour the bar Red. Have followed all steps of choosing Colour Bar/ in Draw Style in Subgraph and choosing right colours. but bars do not get coloured. I noticed that if I type in TRUE & it is text...then bars get coloured. but if True is not typed in manually, but is formula driven...no colouring. I also wrote up a formula to convert formula driven TRUE into =text(CELL A,""), CELL A is formula driven TRUE, otherwise converting into text ....still no recognition. Can you advise where I am wrong?
[2016-04-14 10:41:54]
Use the values 1 and 0 only.
Or just write the formula so that it returns a Boolean result.
For example: =AA>10
