Date/Time: Fri, 27 Dec 2024 16:31:40 +0000
Fisher Transform
View Count: 816
[2016-04-14 01:19:14] |
User469312 - Posts: 97 |
I know that Sierra dose not provide programming advise but I am hoping that someone can assist me on this board. I am having some trouble (difficulty) programming with the Fisher transform indicator. I am using this on Bond futures (ZB) on a range chart setting. I am trying to have a buy signal when Fisher Transform (SG2) crosses above or turns up over (SG3). Same for the sell's but the opposite. I know I need to filter it and there are a few other inputs to clear up the strategy but I am looking for a basic help here so I can work around it from this point. thanking in advance for any help in this matter.
[2016-04-14 04:37:23] |
It sounds like you want to use one of the CROSSOVER functions assuming you are using Spreadsheets: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetFunctions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
