Date/Time: Fri, 27 Dec 2024 16:20:36 +0000
Historical data missing (using Transact)
View Count: 836
[2016-04-13 21:09:19] |
User138207 - Posts: 1 |
I use Transact and am able to receive the live data feed. However, historical (intraday) data are missing. I am using version 1369 and this has been going on for several months now. Can you please help? My log is as follows: Software version: 1369 | 2016-04-13 16:14:54 Uses New Spreadsheets | 2016-04-13 16:14:54 Enabled for: Advanced Features. | 2016-04-13 16:14:54 Enabled for: Advanced Features 2. | 2016-04-13 16:14:54 Enabled for: Sierra Chart Historical Data Service. | 2016-04-13 16:14:54 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-04-13 16:14:54 Current selected Data/Trading service: TransAct Trading | 2016-04-13 16:14:54 Chart Update Interval: 500 | 2016-04-13 16:14:54 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-04-13 16:14:54 2016-04-13 16:14:58 Local computer time | 2016-04-13 16:14:54 2016-04-13 20:14:58 Local computer time in UTC | 2016-04-13 16:14:54 2016-04-13 16:14:58 Local computer time in SC Time Zone | 2016-04-13 16:14:54 2016-04-13 20:14:47 Server time in UTC | 2016-04-13 16:14:54 Local computer UTC time and Server UTC time difference: 11 seconds. | 2016-04-13 16:14:54 Program path: C:\SierraChart\SierraChartTransActMA\ | 2016-04-13 16:14:54 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2016-04-13 16:14:54 OS Version Number: 5.1 | 2016-04-13 16:14:54 Locale Information: C | 2016-04-13 16:14:54 Checking for new symbol settings for ta | 2016-04-13 16:14:54 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-13 16:14:54 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-04-13 16:14:54 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-04-13 16:14:54 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-04-13 16:14:54 Symbol settings are up-to-date for ta | 2016-04-13 16:15:00 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-13 16:15:01 HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-04-13 16:15:01 Files to Open on Start up | Opening file: Starter Chartbook.cht | 2016-04-13 16:15:02 Files to Open on Start up | Opening file: Advanced Chart Types.cht | 2016-04-13 16:15:02 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-13 16:15:03 HD Request # 2 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:15:03 HD Request # 2 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:15:03 HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:15:03 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:15:03 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-04-13 16:15:03 Intraday data recording state for symbol CLK6 is set to download 'Pending'. | 2016-04-13 16:15:03 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2016-04-13 16:15:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-04-13 16:15:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-04-13 16:15:05 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-04-13 16:15:05 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-04-13 16:15:07 Socket (6) | Connected. | 2016-04-13 16:15:07 TransAct Trading | Connected to server. | 2016-04-13 16:15:07 TransAct Trading | Sending logon request message. | 2016-04-13 16:15:07 Socket (5) | Shutdown and closed. | 2016-04-13 16:15:23 HD Request # 2 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:15:23 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:15:23 HD Request # 3 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:15:23 HD Request # 3 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:15:23 HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:15:23 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:15:23 TransAct Trading | Received logon response. | 2016-04-13 16:15:25 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-04-13 16:15:25 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-04-13 16:15:25 TransAct Trading | Successfully connected. Operation Successful. | 2016-04-13 16:15:25 TransAct Trading | Trading is supported. | 2016-04-13 16:15:25 TransAct Trading | Order cancel and replace is supported. | 2016-04-13 16:15:25 TransAct Trading | Connected to data and trading server. | 2016-04-13 16:15:25 TransAct Trading | Starting real-time market data updates for: CLj6. ID: 1 | 2016-04-13 16:15:25 Intraday data recording state for symbol CLj6 is set to download 'Pending'. | 2016-04-13 16:15:25 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 2 | 2016-04-13 16:15:25 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-04-13 16:15:25 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-13 16:15:25 Historical Intraday data request for ESM6 is discarded because a matching download is in progress and the new one is not for earlier data. | 2016-04-13 16:15:25 Intraday data recording state for symbol ESM6 has been reset to 'Downloading'. | 2016-04-13 16:15:25 Symbol Error - CLj6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:15:25 Symbol Error - ESH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:15:25 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:15:25 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 4 | 2016-04-13 16:15:25 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 443 | 2016-04-13 16:15:25 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-04-13 16:15:25 Historical Intraday data request for TICK-NYSE is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-04-13 16:15:25 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:15:26 Socket (8) | Connected. | 2016-04-13 16:15:26 SC DTC Data | Connected to server. | 2016-04-13 16:15:26 SC DTC Data | Sending Encoding Request to server | 2016-04-13 16:15:26 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-04-13 16:15:26 SC DTC Data | Sending logon request message. | 2016-04-13 16:15:26 TransAct Trading | Starting real-time market data updates for: CLK6. ID: 5 | 2016-04-13 16:15:26 Intraday data recording state for symbol CLK6 is set to download 'Pending'. | 2016-04-13 16:15:26 Historical Intraday data request for CLK6 is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-04-13 16:15:26 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:15:26 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 6 | 2016-04-13 16:15:26 TransAct Trading | Starting real-time market data updates for: 6EM6. ID: 7 | 2016-04-13 16:15:26 TransAct Trading | Starting real-time market data updates for: ZNM6. ID: 8 | 2016-04-13 16:15:26 TransAct Trading | Starting real-time market data updates for: FESXM6. ID: 9 | 2016-04-13 16:15:26 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:15:26 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:15:26 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:15:26 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:15:26 SC DTC Data | Received logon response. | 2016-04-13 16:15:26 SC DTC Data | Server Name: SC Real-Time Server. | 2016-04-13 16:15:26 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-04-13 16:15:26 SC DTC Data | Successfully connected. | 2016-04-13 16:15:26 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-04-13 16:15:26 CLK6 [CV] 356 Trades #2 | Date rule based rollover from CLJ6 to next contract occurs at 2016-03-21. | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Date rule based rollover from CLK6 to next contract occurs at 2016-04-19. | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Checking Intraday data file for symbol CLJ6 for the date range from 2016-02-19 to 2016-03-21. | 2016-04-13 16:15:39 Removed historical data download ID 4 | 2016-04-13 16:15:39 Historical Intraday data request for CLJ6 matches existing queued download and replaces existing request since earlier data is requested. | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-19 to 2016-03-21. | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Checking Intraday data file for symbol CLK6 for the date range from 2016-03-21 to 0. | 2016-04-13 16:15:39 Removed historical data download ID 3 | 2016-04-13 16:15:39 Historical Intraday data request for CLK6 matches existing queued download and replaces existing request since earlier data is requested. | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-21 to 2016-04-13. | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Price data for daily data file CLK16.dly. Date: 2016-03-21, Price: 41.52. Date: 2016-04-13, Price: 41.54 | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Price data for daily data file CLJ16.dly. Date: 2016-02-19, Price: 31.75. Date: 2016-03-18, Price: 39.44 | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Symbols used for continuous contract chart: | 2016-04-13 16:15:39 CLJ16 | 2016-04-13 16:15:39 CLK16 | 2016-04-13 16:15:39 CLK6 [CV] 356 Trades #2 | Waiting for historical downloads to complete with the IDs: 9, 10, | 2016-04-13 16:15:39 Socket (7) | Shutdown and closed. | 2016-04-13 16:15:43 HD Request # 3 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:15:43 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:15:43 HD Request # 4 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:15:43 HD Request # 4 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:15:43 HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:15:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:15:43 HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-04-13 16:16:02 HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-04-13 16:16:02 Socket (9) | Shutdown and closed. | 2016-04-13 16:16:03 HD Request # 4 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:16:03 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:16:03 HD Request # 4 | Intraday download COMPLETE for ESM6. Completion time: 20s. Unique request ID: 1 | 2016-04-13 16:16:03 Removed historical data download ID 1 | 2016-04-13 16:16:03 Real-time Intraday chart data file updates started for ESM6 | 2016-04-13 16:16:03 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\ESM6.scid | 2016-04-13 16:16:03 Intraday chart data file opened for ESM6 | 2016-04-13 16:16:03 HD Request # 5 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-04-13 16:16:03 HD Request # 5 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:16:03 HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:16:03 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:16:03 Socket (10) | Shutdown and closed. | 2016-04-13 16:16:23 HD Request # 5 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2016-04-13 16:16:23 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-04-13 16:16:23 HD Request # 6 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-04-13 16:16:23 HD Request # 6 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:16:23 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:16:23 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:16:23 Socket (11) | Shutdown and closed. | 2016-04-13 16:16:43 HD Request # 6 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2016-04-13 16:16:43 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-04-13 16:16:43 HD Request # 7 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-04-13 16:16:43 HD Request # 7 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:16:43 HD Request # 7 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:16:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:16:43 Socket (12) | Shutdown and closed. | 2016-04-13 16:17:03 HD Request # 7 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2016-04-13 16:17:03 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-04-13 16:17:03 HD Request # 7 | Intraday download COMPLETE for TICK-NYSE. Completion time: 20s. Unique request ID: 2 | 2016-04-13 16:17:03 Removed historical data download ID 2 | 2016-04-13 16:17:03 Real-time Intraday chart data file updates started for TICK-NYSE | 2016-04-13 16:17:03 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\TICK-NYSE.scid | 2016-04-13 16:17:03 Intraday chart data file opened for TICK-NYSE | 2016-04-13 16:17:03 HD Request # 8 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:17:03 HD Request # 8 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:17:03 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:17:03 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:17:03 Socket (14) | Shutdown and closed. | 2016-04-13 16:17:23 HD Request # 8 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:17:23 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:17:23 HD Request # 9 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:17:23 HD Request # 9 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:17:23 HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:17:23 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:17:23 Socket (15) | Shutdown and closed. | 2016-04-13 16:17:43 HD Request # 9 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:17:43 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:17:43 HD Request # 10 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:17:43 HD Request # 10 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:17:43 HD Request # 10 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:17:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:17:43 Socket (16) | Shutdown and closed. | 2016-04-13 16:18:03 HD Request # 10 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:18:03 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:18:03 HD Request # 10 | Intraday download COMPLETE for ESH6. Completion time: 20s. Unique request ID: 5 | 2016-04-13 16:18:03 Removed historical data download ID 5 | 2016-04-13 16:18:03 Real-time Intraday chart data file updates started for ESH6 | 2016-04-13 16:18:03 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\ESH6.scid | 2016-04-13 16:18:03 Intraday chart data file opened for ESH6 | 2016-04-13 16:18:03 HD Request # 11 | Downloading Intraday chart data for CLJ6 to the file CLJ6.scid. Service: ta | 2016-04-13 16:18:03 HD Request # 11 | Download start Date-Time: 2016-02-11 18:59:59.000 | 2016-04-13 16:18:03 HD Request # 11 | Disabling Intraday chart updating for symbol during historical data download. | 2016-04-13 16:18:03 HD Request # 11 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:18:03 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:18:03 Socket (17) | Shutdown and closed. | 2016-04-13 16:18:23 HD Request # 11 | Error downloading historical Intraday data for CLJ6. The network socket has been closed. Retrying download. | 2016-04-13 16:18:23 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLJ6 | 2016-04-13 16:18:23 HD Request # 12 | Downloading Intraday chart data for CLJ6 to the file CLJ6.scid. Service: ta | 2016-04-13 16:18:23 HD Request # 12 | Download start Date-Time: 2016-02-11 18:59:59.000 | 2016-04-13 16:18:23 HD Request # 12 | Disabling Intraday chart updating for symbol during historical data download. | 2016-04-13 16:18:23 HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:18:23 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:18:23 Socket (18) | Shutdown and closed. | 2016-04-13 16:18:43 HD Request # 12 | Error downloading historical Intraday data for CLJ6. The network socket has been closed. Retrying download. | 2016-04-13 16:18:43 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLJ6 | 2016-04-13 16:18:43 HD Request # 13 | Downloading Intraday chart data for CLJ6 to the file CLJ6.scid. Service: ta | 2016-04-13 16:18:43 HD Request # 13 | Download start Date-Time: 2016-02-11 18:59:59.000 | 2016-04-13 16:18:43 HD Request # 13 | Disabling Intraday chart updating for symbol during historical data download. | 2016-04-13 16:18:43 HD Request # 13 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:18:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:18:43 Socket (19) | Shutdown and closed. | 2016-04-13 16:19:03 HD Request # 13 | Error downloading historical Intraday data for CLJ6. The network socket has been closed. Retrying download. | 2016-04-13 16:19:03 HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLJ6 | 2016-04-13 16:19:03 HD Request # 13 | Intraday download COMPLETE for CLJ6. Completion time: 20s. Unique request ID: 9 | 2016-04-13 16:19:03 Removed historical data download ID 9 | 2016-04-13 16:19:03 Real-time Intraday chart data file updates started for CLj6 | 2016-04-13 16:19:03 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\CLj6.scid | 2016-04-13 16:19:03 Intraday chart data file opened for CLj6 | 2016-04-13 16:19:03 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2016-04-13 16:19:03 HD Request # 14 | Downloading Intraday chart data for CLK6 to the file CLK6.scid. Service: ta | 2016-04-13 16:19:03 HD Request # 14 | Download start Date-Time: 2016-03-13 19:59:59.000 | 2016-04-13 16:19:03 HD Request # 14 | Disabling Intraday chart updating for symbol during historical data download. | 2016-04-13 16:19:03 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:19:03 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:19:03 Socket (21) | Shutdown and closed. | 2016-04-13 16:19:23 HD Request # 14 | Error downloading historical Intraday data for CLK6. The network socket has been closed. Retrying download. | 2016-04-13 16:19:23 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLK6 | 2016-04-13 16:19:23 HD Request # 15 | Downloading Intraday chart data for CLK6 to the file CLK6.scid. Service: ta | 2016-04-13 16:19:23 HD Request # 15 | Download start Date-Time: 2016-03-13 19:59:59.000 | 2016-04-13 16:19:23 HD Request # 15 | Disabling Intraday chart updating for symbol during historical data download. | 2016-04-13 16:19:23 HD Request # 15 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:19:23 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:19:23 Socket (22) | Shutdown and closed. | 2016-04-13 16:19:43 HD Request # 15 | Error downloading historical Intraday data for CLK6. The network socket has been closed. Retrying download. | 2016-04-13 16:19:43 HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLK6 | 2016-04-13 16:19:43 HD Request # 16 | Downloading Intraday chart data for CLK6 to the file CLK6.scid. Service: ta | 2016-04-13 16:19:43 HD Request # 16 | Download start Date-Time: 2016-03-13 19:59:59.000 | 2016-04-13 16:19:43 HD Request # 16 | Disabling Intraday chart updating for symbol during historical data download. | 2016-04-13 16:19:43 HD Request # 16 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:19:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:19:43 Socket (23) | Shutdown and closed. | 2016-04-13 16:20:03 HD Request # 16 | Error downloading historical Intraday data for CLK6. The network socket has been closed. Retrying download. | 2016-04-13 16:20:03 HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLK6 | 2016-04-13 16:20:03 HD Request # 16 | Receiving Intraday data for CLK6 starting at 2016-04-13 16:15:17 | 2016-04-13 16:20:03 HD Request # 16 | Truncating file to starting Date-Time of 2016-04-13 16:15:17 | 2016-04-13 16:20:03 HD Request # 16 | Error jumping to date-time during truncate. Error: Date-Time is beyond last record in file. | 2016-04-13 16:20:03 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-04-13 16:15:17 | 2016-04-13 16:20:03 Added 46 Time and Sales records to Intraday data file for CLK6 after download. | 2016-04-13 16:20:03 HD Request # 16 | Intraday download COMPLETE for CLK6. Completion time: 20s. Unique request ID: 10 | 2016-04-13 16:20:03 Removed historical data download ID 10 | 2016-04-13 16:20:03 Real-time Intraday chart data file updates started for CLK6 | 2016-04-13 16:20:03 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\CLK6.scid | 2016-04-13 16:20:03 Intraday chart data file opened for CLK6 | 2016-04-13 16:20:03 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2016-04-13 16:20:03 HD Request # 16 | Reloading Intraday charts for CLK6 | 2016-04-13 16:20:03 Reloading all charts with filename: CLK6.scid | 2016-04-13 16:20:03 CLk6 0.02 Range #11 | Reloading chart. | 2016-04-13 16:20:03 CLK6 1 Min 40 Sec #9 | Reloading chart. | 2016-04-13 16:20:03 CLK6 37 Trades #3 | Reloading chart. | 2016-04-13 16:20:03 CLK6 1 Min 40 Sec #1 | Reloading chart. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Reloading chart. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Date rule based rollover from CLJ6 to next contract occurs at 2016-03-21. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Date rule based rollover from CLK6 to next contract occurs at 2016-04-19. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Skipping checking Intraday data file for symbol CLJ6 since download was already done in last 24 hours. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Checking Daily data file for symbol CLJ16 for the date range from 2016-02-19 to 2016-03-21. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Skipping checking Intraday data file for symbol CLK6 since download was already done in last 24 hours. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Checking Daily data file for symbol CLK16 for the date range from 2016-03-21 to 2016-04-13. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Price data for daily data file CLK16.dly. Date: 2016-03-21, Price: 41.52. Date: 2016-04-13, Price: 41.54 | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Price data for daily data file CLJ16.dly. Date: 2016-02-19, Price: 31.75. Date: 2016-03-18, Price: 39.44 | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Symbols used for continuous contract chart: | 2016-04-13 16:20:03 CLJ16 | 2016-04-13 16:20:03 CLK16 | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Checking for volume based rollover dates. | 2016-04-13 16:20:03 CLK6 [CV] 356 Trades #2 | Volume based rollover from CLJ6 to CLK6 occurs at 2016-03-17 | 2016-04-13 16:20:03 CLK6 3 Min #7 | Reloading chart. | 2016-04-13 16:20:04 Checking for new symbol settings for ta | 2016-04-13 16:44:17 Current selected Data/Trading service: TransAct Trading | 2016-04-13 16:44:17 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-13 16:44:17 HTTPS connection to www.sierrachart.com:443 (36) | Connected. | 2016-04-13 16:44:17 HTTPS connection to www.sierrachart.com:443 (36) | Starting TLS 1.2 connection. | 2016-04-13 16:44:17 HTTPS connection to www.sierrachart.com:443 (36) | SSL connection established. | 2016-04-13 16:44:17 Requesting symbol settings for ta. Overwrite = on. | 2016-04-13 16:44:18 Numbers Bars study: Setting 'Intraday Data Storage Time Unit' to 1 Tick. Will need to re-download data in chart for historical data accuracy. | 2016-04-13 16:44:18 * Symbol settings received. | 2016-04-13 16:44:18 Processed received symbol settings | 2016-04-13 16:44:18 Reconnecting to the data feed after processing symbol settings. | 2016-04-13 16:44:18 Socket (6) | Shutdown and closed. | 2016-04-13 16:44:18 Socket (8) | Shutdown and closed. | 2016-04-13 16:44:18 SC DTC Data | Disconnected from the server. | 2016-04-13 16:44:18 TransAct Trading | Disconnected. | 2016-04-13 16:44:18 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-13 16:44:18 HTTPS connection to www.sierrachart.com:443 (36) | SSL connection closed by remote side. | 2016-04-13 16:44:23 HTTPS connection to www.sierrachart.com:443 (36) | SSL object has been freed. SSL state is now disconnected. | 2016-04-13 16:44:23 HTTPS connection to www.sierrachart.com:443 (36) | Shutdown and closed. | 2016-04-13 16:44:23 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2016-04-13 16:44:23 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-04-13 16:44:25 Socket (37) | Connected. | 2016-04-13 16:44:25 TransAct Trading | Connected to server. | 2016-04-13 16:44:25 TransAct Trading | Sending logon request message. | 2016-04-13 16:44:25 TransAct Trading | Received logon response. | 2016-04-13 16:44:29 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-04-13 16:44:29 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-04-13 16:44:29 TransAct Trading | Successfully connected. Operation Successful. | 2016-04-13 16:44:29 TransAct Trading | Trading is supported. | 2016-04-13 16:44:29 TransAct Trading | Order cancel and replace is supported. | 2016-04-13 16:44:29 TransAct Trading | Connected to data and trading server. | 2016-04-13 16:44:29 TransAct Trading | Starting real-time market data updates for: CLj6. ID: 1 | 2016-04-13 16:44:29 Intraday data recording state for symbol CLj6 is set to download 'Pending'. | 2016-04-13 16:44:29 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 2 | 2016-04-13 16:44:29 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-04-13 16:44:29 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-13 16:44:29 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-13 16:44:29 Symbol Error - CLj6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:44:29 Symbol Error - ESH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:44:29 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:44:29 HD Request # 17 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:44:29 HD Request # 17 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:44:29 HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:44:29 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:44:29 TransAct Trading | Starting real-time market data updates for: CLk6. ID: 4 | 2016-04-13 16:44:29 Intraday data recording state for symbol CLk6 is set to download 'Pending'. | 2016-04-13 16:44:29 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:44:29 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 5 | 2016-04-13 16:44:29 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-04-13 16:44:29 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-04-13 16:44:29 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:44:29 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 6 | 2016-04-13 16:44:30 TransAct Trading | Starting real-time market data updates for: 6EM6. ID: 7 | 2016-04-13 16:44:30 TransAct Trading | Starting real-time market data updates for: ZNM6. ID: 8 | 2016-04-13 16:44:30 TransAct Trading | Starting real-time market data updates for: FESXM6. ID: 9 | 2016-04-13 16:44:30 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:44:30 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:44:30 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:44:30 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:44:30 Socket (38) | Shutdown and closed. | 2016-04-13 16:44:49 HD Request # 17 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:44:49 HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:44:49 HD Request # 18 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:44:49 HD Request # 18 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:44:49 HD Request # 18 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:44:49 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:44:49 Socket (39) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-04-13 16:44:50 Socket (39) | Shutdown and closed. | 2016-04-13 16:44:50 SC DTC Data | Disconnected from the server. | 2016-04-13 16:44:50 SC DTC Data | Data feed disconnected. Will reconnect. | 2016-04-13 16:44:50 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-04-13 16:44:52 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:44:52 Socket (41) | Connected. | 2016-04-13 16:44:53 SC DTC Data | Connected to server. | 2016-04-13 16:44:53 SC DTC Data | Sending Encoding Request to server | 2016-04-13 16:44:53 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-04-13 16:44:53 SC DTC Data | Sending logon request message. | 2016-04-13 16:44:53 SC DTC Data | Received logon response. | 2016-04-13 16:44:53 SC DTC Data | Server Name: SC Real-Time Server. | 2016-04-13 16:44:53 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-04-13 16:44:53 SC DTC Data | Successfully connected. | 2016-04-13 16:44:53 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-04-13 16:44:53 Socket (40) | Shutdown and closed. | 2016-04-13 16:45:09 HD Request # 18 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:45:09 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:45:09 HD Request # 19 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:45:09 HD Request # 19 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:45:09 HD Request # 19 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:45:09 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:45:09 Socket (43) | Shutdown and closed. | 2016-04-13 16:45:29 HD Request # 19 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:45:29 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:45:29 HD Request # 19 | Intraday download COMPLETE for CLj6. Completion time: 20s. Unique request ID: 11 | 2016-04-13 16:45:29 Removed historical data download ID 11 | 2016-04-13 16:45:29 Real-time Intraday chart data file updates started for CLj6 | 2016-04-13 16:45:29 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\CLj6.scid | 2016-04-13 16:45:29 Intraday chart data file opened for CLj6 | 2016-04-13 16:45:29 HD Request # 20 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:45:29 HD Request # 20 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:45:29 HD Request # 20 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:45:29 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:45:29 Checking for new symbol settings for ta | 2016-04-13 16:45:45 Current selected Data/Trading service: TransAct Trading | 2016-04-13 16:45:45 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-13 16:45:45 HTTPS connection to www.sierrachart.com:443 (45) | Connected. | 2016-04-13 16:45:46 HTTPS connection to www.sierrachart.com:443 (45) | Starting TLS 1.2 connection. | 2016-04-13 16:45:46 HTTPS connection to www.sierrachart.com:443 (45) | SSL connection established. | 2016-04-13 16:45:46 Requesting symbol settings for ta. Overwrite = on. | 2016-04-13 16:45:46 Symbol settings received. | 2016-04-13 16:45:46 Processed received symbol settings | 2016-04-13 16:45:46 Reconnecting to the data feed after processing symbol settings. | 2016-04-13 16:45:46 Canceling download request for ESM6 Intraday data. | 2016-04-13 16:45:46 Removed historical data download ID 13 | 2016-04-13 16:45:46 Canceling download request for CLk6 Intraday data. | 2016-04-13 16:45:46 Removed historical data download ID 14 | 2016-04-13 16:45:46 Canceling download request for TICK-NYSE Intraday data. | 2016-04-13 16:45:46 Removed historical data download ID 15 | 2016-04-13 16:45:46 HD Request # 20 | Download canceled. | 2016-04-13 16:45:46 Socket (44) | Shutdown and closed. | 2016-04-13 16:45:46 HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:45:46 HD Request # 20 | Intraday download COMPLETE for ESH6. Completion time: 17s. Unique request ID: 12 | 2016-04-13 16:45:46 Removed historical data download ID 12 | 2016-04-13 16:45:46 Socket (37) | Shutdown and closed. | 2016-04-13 16:45:46 Socket (41) | Shutdown and closed. | 2016-04-13 16:45:46 SC DTC Data | Disconnected from the server. | 2016-04-13 16:45:46 TransAct Trading | Disconnected. | 2016-04-13 16:45:46 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-13 16:45:46 HTTPS connection to www.sierrachart.com:443 (45) | SSL connection closed by remote side. | 2016-04-13 16:45:51 HTTPS connection to www.sierrachart.com:443 (45) | SSL object has been freed. SSL state is now disconnected. | 2016-04-13 16:45:51 HTTPS connection to www.sierrachart.com:443 (45) | Shutdown and closed. | 2016-04-13 16:45:51 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2016-04-13 16:45:51 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-04-13 16:45:53 Socket (46) | Connected. | 2016-04-13 16:45:53 TransAct Trading | Connected to server. | 2016-04-13 16:45:53 TransAct Trading | Sending logon request message. | 2016-04-13 16:45:53 TransAct Trading | Received logon response. | 2016-04-13 16:46:00 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-04-13 16:46:00 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-04-13 16:46:00 TransAct Trading | Successfully connected. Operation Successful. | 2016-04-13 16:46:00 TransAct Trading | Trading is supported. | 2016-04-13 16:46:00 TransAct Trading | Order cancel and replace is supported. | 2016-04-13 16:46:00 TransAct Trading | Connected to data and trading server. | 2016-04-13 16:46:00 TransAct Trading | Starting real-time market data updates for: CLj6. ID: 1 | 2016-04-13 16:46:00 Intraday data recording state for symbol CLj6 is set to download 'Pending'. | 2016-04-13 16:46:00 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 2 | 2016-04-13 16:46:00 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-04-13 16:46:00 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-13 16:46:00 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-13 16:46:00 Symbol Error - CLj6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:46:00 Symbol Error - ESH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:46:00 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:46:00 HD Request # 21 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:46:00 HD Request # 21 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:46:00 HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:46:00 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:46:00 TransAct Trading | Starting real-time market data updates for: CLk6. ID: 4 | 2016-04-13 16:46:00 Intraday data recording state for symbol CLk6 is set to download 'Pending'. | 2016-04-13 16:46:00 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:46:00 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 5 | 2016-04-13 16:46:00 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-04-13 16:46:00 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-04-13 16:46:00 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:46:00 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 6 | 2016-04-13 16:46:01 TransAct Trading | Starting real-time market data updates for: 6EM6. ID: 7 | 2016-04-13 16:46:01 TransAct Trading | Starting real-time market data updates for: ZNM6. ID: 8 | 2016-04-13 16:46:01 TransAct Trading | Starting real-time market data updates for: FESXM6. ID: 9 | 2016-04-13 16:46:01 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:46:01 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:46:01 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:46:01 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:46:01 Socket (47) | Shutdown and closed. | 2016-04-13 16:46:20 HD Request # 21 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:46:20 HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:46:20 HD Request # 22 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:46:20 HD Request # 22 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:46:20 HD Request # 22 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:46:20 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:46:20 Socket (48) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-04-13 16:46:21 Socket (48) | Shutdown and closed. | 2016-04-13 16:46:21 SC DTC Data | Disconnected from the server. | 2016-04-13 16:46:21 SC DTC Data | Data feed disconnected. Will reconnect. | 2016-04-13 16:46:21 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-04-13 16:46:23 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:46:23 Socket (50) | Connected. | 2016-04-13 16:46:23 SC DTC Data | Connected to server. | 2016-04-13 16:46:23 SC DTC Data | Sending Encoding Request to server | 2016-04-13 16:46:23 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-04-13 16:46:23 SC DTC Data | Sending logon request message. | 2016-04-13 16:46:23 SC DTC Data | Received logon response. | 2016-04-13 16:46:23 SC DTC Data | Server Name: SC Real-Time Server. | 2016-04-13 16:46:23 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-04-13 16:46:23 SC DTC Data | Successfully connected. | 2016-04-13 16:46:23 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-04-13 16:46:23 TransAct Trading | Starting real-time market data updates for: GCM6. ID: 10 | 2016-04-13 16:46:30 Intraday data recording state for symbol GCM6 is set to download 'Pending'. | 2016-04-13 16:46:30 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:46:30 Socket (49) | Shutdown and closed. | 2016-04-13 16:46:40 HD Request # 22 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:46:40 HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:46:40 HD Request # 23 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:46:40 HD Request # 23 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:46:40 HD Request # 23 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:46:40 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:46:40 Socket (51) | Shutdown and closed. | 2016-04-13 16:47:00 HD Request # 23 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:47:00 HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:47:00 HD Request # 23 | Intraday download COMPLETE for CLj6. Completion time: 20s. Unique request ID: 16 | 2016-04-13 16:47:00 Removed historical data download ID 16 | 2016-04-13 16:47:00 Real-time Intraday chart data file updates started for CLj6 | 2016-04-13 16:47:00 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\CLj6.scid | 2016-04-13 16:47:00 Intraday chart data file opened for CLj6 | 2016-04-13 16:47:00 HD Request # 24 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:47:00 HD Request # 24 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:47:00 HD Request # 24 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:47:00 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:47:00 Socket (53) | Shutdown and closed. | 2016-04-13 16:47:20 HD Request # 24 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:47:20 HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:47:20 HD Request # 25 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:47:20 HD Request # 25 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:47:20 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:47:20 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:47:20 Socket (54) | Shutdown and closed. | 2016-04-13 16:47:40 HD Request # 25 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:47:40 HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:47:40 HD Request # 26 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:47:40 HD Request # 26 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:47:40 HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:47:40 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:47:40 Socket (55) | Shutdown and closed. | 2016-04-13 16:48:00 HD Request # 26 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:48:00 HD Request # 26 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:48:00 HD Request # 26 | Intraday download COMPLETE for ESH6. Completion time: 20s. Unique request ID: 17 | 2016-04-13 16:48:00 Removed historical data download ID 17 | 2016-04-13 16:48:00 Real-time Intraday chart data file updates started for ESH6 | 2016-04-13 16:48:00 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\ESH6.scid | 2016-04-13 16:48:00 Intraday chart data file opened for ESH6 | 2016-04-13 16:48:00 HD Request # 27 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:48:00 HD Request # 27 | Download start Date-Time: 2016-04-13 16:44:04.000 | 2016-04-13 16:48:00 HD Request # 27 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:48:00 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:48:00 Socket (56) | Shutdown and closed. | 2016-04-13 16:48:20 HD Request # 27 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:48:20 HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:48:20 HD Request # 28 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:48:20 HD Request # 28 | Download start Date-Time: 2016-04-13 16:44:04.000 | 2016-04-13 16:48:20 HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:48:20 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:48:20 Checking for new symbol settings for ta | 2016-04-13 16:48:30 Current selected Data/Trading service: TransAct Trading | 2016-04-13 16:48:30 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-04-13 16:48:30 HTTPS connection to www.sierrachart.com:443 (58) | Connected. | 2016-04-13 16:48:31 HTTPS connection to www.sierrachart.com:443 (58) | Starting TLS 1.2 connection. | 2016-04-13 16:48:31 HTTPS connection to www.sierrachart.com:443 (58) | SSL connection established. | 2016-04-13 16:48:31 Requesting symbol settings for ta. Overwrite = on. | 2016-04-13 16:48:31 Symbol settings received. | 2016-04-13 16:48:31 Processed received symbol settings | 2016-04-13 16:48:31 Reconnecting to the data feed after processing symbol settings. | 2016-04-13 16:48:31 Numbers Bars study: Setting 'Intraday Data Storage Time Unit' to 1 Tick. Will need to re-download data in chart for historical data accuracy. | 2016-04-13 16:48:31 * Canceling download request for CLk6 Intraday data. | 2016-04-13 16:48:31 Removed historical data download ID 19 | 2016-04-13 16:48:31 Canceling download request for TICK-NYSE Intraday data. | 2016-04-13 16:48:31 Removed historical data download ID 20 | 2016-04-13 16:48:31 Canceling download request for GCM6 Intraday data. | 2016-04-13 16:48:31 Removed historical data download ID 21 | 2016-04-13 16:48:31 HD Request # 28 | Download canceled. | 2016-04-13 16:48:31 Socket (57) | Shutdown and closed. | 2016-04-13 16:48:31 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:48:31 HD Request # 28 | Intraday download COMPLETE for ESM6. Completion time: 11s. Unique request ID: 18 | 2016-04-13 16:48:31 Removed historical data download ID 18 | 2016-04-13 16:48:31 Socket (46) | Shutdown and closed. | 2016-04-13 16:48:31 Socket (50) | Shutdown and closed. | 2016-04-13 16:48:31 SC DTC Data | Disconnected from the server. | 2016-04-13 16:48:31 TransAct Trading | Disconnected. | 2016-04-13 16:48:31 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-13 16:48:31 HTTPS connection to www.sierrachart.com:443 (58) | SSL connection closed by remote side. | 2016-04-13 16:48:36 HTTPS connection to www.sierrachart.com:443 (58) | SSL object has been freed. SSL state is now disconnected. | 2016-04-13 16:48:36 HTTPS connection to www.sierrachart.com:443 (58) | Shutdown and closed. | 2016-04-13 16:48:36 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2016-04-13 16:48:37 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-04-13 16:48:39 Socket (59) | Connected. | 2016-04-13 16:48:39 TransAct Trading | Connected to server. | 2016-04-13 16:48:39 TransAct Trading | Sending logon request message. | 2016-04-13 16:48:39 TransAct Trading | Received logon response. | 2016-04-13 16:48:42 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-04-13 16:48:42 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-04-13 16:48:42 TransAct Trading | Successfully connected. Operation Successful. | 2016-04-13 16:48:42 TransAct Trading | Trading is supported. | 2016-04-13 16:48:42 TransAct Trading | Order cancel and replace is supported. | 2016-04-13 16:48:42 TransAct Trading | Connected to data and trading server. | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: CLj6. ID: 1 | 2016-04-13 16:48:42 Intraday data recording state for symbol CLj6 is set to download 'Pending'. | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 2 | 2016-04-13 16:48:42 Intraday data recording state for symbol ESH6 is set to download 'Pending'. | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-13 16:48:42 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-13 16:48:42 Symbol Error - CLj6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:48:42 Symbol Error - ESH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:48:42 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:48:42 HD Request # 29 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:48:42 HD Request # 29 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:48:42 HD Request # 29 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:48:42 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: GCM6. ID: 4 | 2016-04-13 16:48:42 Intraday data recording state for symbol GCM6 is set to download 'Pending'. | 2016-04-13 16:48:42 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: CLk6. ID: 5 | 2016-04-13 16:48:42 Intraday data recording state for symbol CLk6 is set to download 'Pending'. | 2016-04-13 16:48:42 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:48:42 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 6 | 2016-04-13 16:48:42 SC DTC Data | Connecting to the server ds5.sierracharts.com. Port 10048 | 2016-04-13 16:48:42 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-04-13 16:48:42 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 7 | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: 6EM6. ID: 8 | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: ZNM6. ID: 9 | 2016-04-13 16:48:42 TransAct Trading | Starting real-time market data updates for: FESXM6. ID: 10 | 2016-04-13 16:48:42 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:48:42 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:48:42 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:48:42 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:48:42 Socket (60) | Shutdown and closed. | 2016-04-13 16:49:02 HD Request # 29 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:49:02 HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:49:02 HD Request # 30 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:49:02 HD Request # 30 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:49:02 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:49:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:49:02 Socket (61) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-04-13 16:49:03 Socket (61) | Shutdown and closed. | 2016-04-13 16:49:03 SC DTC Data | Disconnected from the server. | 2016-04-13 16:49:03 SC DTC Data | Data feed disconnected. Will reconnect. | 2016-04-13 16:49:03 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 443 | 2016-04-13 16:49:05 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:49:05 Socket (64) | Connected. | 2016-04-13 16:49:05 SC DTC Data | Connected to server. | 2016-04-13 16:49:05 SC DTC Data | Sending Encoding Request to server | 2016-04-13 16:49:05 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-04-13 16:49:05 SC DTC Data | Sending logon request message. | 2016-04-13 16:49:05 SC DTC Data | Received logon response. | 2016-04-13 16:49:05 SC DTC Data | Server Name: SC Real-Time Server. | 2016-04-13 16:49:05 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-04-13 16:49:05 SC DTC Data | Successfully connected. | 2016-04-13 16:49:05 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-04-13 16:49:05 Socket (63) | Shutdown and closed. | 2016-04-13 16:49:22 HD Request # 30 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:49:22 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:49:22 HD Request # 31 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:49:22 HD Request # 31 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:49:22 HD Request # 31 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:49:22 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:49:22 Socket (59) | Closed. No error. | 2016-04-13 16:49:33 Socket (59) | Shutdown and closed. | 2016-04-13 16:49:33 Connection to the external service has been lost. | 2016-04-13 16:49:33 TransAct Trading | Disconnected. | 2016-04-13 16:49:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-04-13 16:49:33 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2016-04-13 16:49:38 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-04-13 16:49:40 Socket (66) | Connected. | 2016-04-13 16:49:40 TransAct Trading | Connected to server. | 2016-04-13 16:49:40 TransAct Trading | Sending logon request message. | 2016-04-13 16:49:40 Socket (65) | Shutdown and closed. | 2016-04-13 16:49:42 HD Request # 31 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:49:42 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:49:42 HD Request # 31 | Intraday download COMPLETE for CLj6. Completion time: 20s. Unique request ID: 22 | 2016-04-13 16:49:42 Removed historical data download ID 22 | 2016-04-13 16:49:42 HD Request # 32 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:49:42 HD Request # 32 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:49:42 HD Request # 32 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:49:42 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:49:42 TransAct Trading | Received logon response. | 2016-04-13 16:49:43 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-04-13 16:49:43 TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-04-13 16:49:43 TransAct Trading | Successfully connected. Operation Successful. | 2016-04-13 16:49:43 TransAct Trading | Trading is supported. | 2016-04-13 16:49:43 TransAct Trading | Order cancel and replace is supported. | 2016-04-13 16:49:43 TransAct Trading | Connected to data and trading server. | 2016-04-13 16:49:43 Socket (64) | Shutdown and closed. | 2016-04-13 16:49:43 SC DTC Data | Disconnected from the server. | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: CLj6. ID: 1 | 2016-04-13 16:49:43 Intraday data recording state for symbol CLj6 is set to download 'Pending'. | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: ESH6. ID: 2 | 2016-04-13 16:49:43 Historical Intraday data request for ESH6 is discarded because a matching download is in progress and the new one is not for earlier data. | 2016-04-13 16:49:43 Intraday data recording state for symbol ESH6 has been reset to 'Downloading'. | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: ESM6. ID: 3 | 2016-04-13 16:49:43 Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-04-13 16:49:43 Historical Intraday data request for ESM6 is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-04-13 16:49:43 Symbol Error - CLj6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:49:43 Symbol Error - ESH6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:49:43 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: GCM6. ID: 4 | 2016-04-13 16:49:43 Intraday data recording state for symbol GCM6 is set to download 'Pending'. | 2016-04-13 16:49:43 Historical Intraday data request for GCM6 is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-04-13 16:49:43 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: TFM6. ID: 5 | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: CLK6. ID: 6 | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: 6EM6. ID: 7 | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: ZNM6. ID: 8 | 2016-04-13 16:49:43 TransAct Trading | Starting real-time market data updates for: FESXM6. ID: 9 | 2016-04-13 16:49:43 Symbol Error - TFM6 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-04-13 16:49:43 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:49:43 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:49:43 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:49:43 DTC - Unrecognized message. Size: 84. Type: 110. | 2016-04-13 16:49:43 Intraday data recording state for symbol CLk6 is set to download 'Pending'. | 2016-04-13 16:49:43 Historical Intraday data request for CLk6 is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-04-13 16:49:43 SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 10 | 2016-04-13 16:49:43 SC DTC Data | Connecting to the server ds3.sierracharts.com. Port 10048 | 2016-04-13 16:49:43 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-04-13 16:49:43 Historical Intraday data request for TICK-NYSE is discarded because a matching download is already pending and the new one is not for earlier data. | 2016-04-13 16:49:43 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:49:43 Socket (67) | Shutdown and closed. | 2016-04-13 16:50:02 HD Request # 32 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:50:02 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:50:02 HD Request # 33 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:50:02 HD Request # 33 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:50:02 HD Request # 33 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:50:02 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:50:02 Socket (68) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-04-13 16:50:04 Socket (68) | Shutdown and closed. | 2016-04-13 16:50:04 SC DTC Data | Disconnected from the server. | 2016-04-13 16:50:04 SC DTC Data | Data feed disconnected. Will reconnect. | 2016-04-13 16:50:04 SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 443 | 2016-04-13 16:50:06 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:50:06 Socket (70) | Connected. | 2016-04-13 16:50:06 SC DTC Data | Connected to server. | 2016-04-13 16:50:06 SC DTC Data | Sending Encoding Request to server | 2016-04-13 16:50:06 SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-04-13 16:50:06 SC DTC Data | Sending logon request message. | 2016-04-13 16:50:06 SC DTC Data | Received logon response. | 2016-04-13 16:50:06 SC DTC Data | Server Name: SC Real-Time Server. | 2016-04-13 16:50:06 SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-04-13 16:50:06 SC DTC Data | Successfully connected. | 2016-04-13 16:50:06 SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-04-13 16:50:06 Socket (69) | Shutdown and closed. | 2016-04-13 16:50:22 HD Request # 33 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:50:22 HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:50:22 HD Request # 34 | Downloading Intraday chart data for ESH6 to the file ESH6.scid. Service: ta | 2016-04-13 16:50:22 HD Request # 34 | Download start Date-Time: 2016-03-11 09:41:19.000 | 2016-04-13 16:50:22 HD Request # 34 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:50:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:50:22 Socket (71) | Shutdown and closed. | 2016-04-13 16:50:42 HD Request # 34 | Error downloading historical Intraday data for ESH6. The network socket has been closed. Retrying download. | 2016-04-13 16:50:42 HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6 | 2016-04-13 16:50:42 HD Request # 34 | Intraday download COMPLETE for ESH6. Completion time: 20s. Unique request ID: 23 | 2016-04-13 16:50:42 Removed historical data download ID 23 | 2016-04-13 16:50:42 Real-time Intraday chart data file updates started for ESH6 | 2016-04-13 16:50:42 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\ESH6.scid | 2016-04-13 16:50:42 Intraday chart data file opened for ESH6 | 2016-04-13 16:50:42 HD Request # 35 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:50:42 HD Request # 35 | Download start Date-Time: 2016-04-13 16:44:04.000 | 2016-04-13 16:50:42 HD Request # 35 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:50:42 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:50:42 Socket (72) | Shutdown and closed. | 2016-04-13 16:51:02 HD Request # 35 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:51:02 HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:51:02 HD Request # 36 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:51:02 HD Request # 36 | Download start Date-Time: 2016-04-13 16:44:04.000 | 2016-04-13 16:51:02 HD Request # 36 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:51:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:51:02 Socket (74) | Shutdown and closed. | 2016-04-13 16:51:22 HD Request # 36 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:51:22 HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:51:22 HD Request # 37 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: ta | 2016-04-13 16:51:22 HD Request # 37 | Download start Date-Time: 2016-04-13 16:44:04.000 | 2016-04-13 16:51:22 HD Request # 37 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:51:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:51:22 Socket (75) | Shutdown and closed. | 2016-04-13 16:51:42 HD Request # 37 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:51:42 HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6 | 2016-04-13 16:51:42 HD Request # 37 | Receiving Intraday data for ESM6 starting at 2016-04-13 16:44:23 | 2016-04-13 16:51:42 HD Request # 37 | Timestamp of first Intraday data file record written: 2016-04-13 16:44:23 | 2016-04-13 16:51:42 Added 329 Time and Sales records to Intraday data file for ESM6 after download. | 2016-04-13 16:51:42 HD Request # 37 | Intraday download COMPLETE for ESM6. Completion time: 20s. Unique request ID: 24 | 2016-04-13 16:51:42 Removed historical data download ID 24 | 2016-04-13 16:51:42 Real-time Intraday chart data file updates started for ESM6 | 2016-04-13 16:51:42 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\ESM6.scid | 2016-04-13 16:51:42 Intraday chart data file opened for ESM6 | 2016-04-13 16:51:42 HD Request # 38 | Downloading Intraday chart data for GCM6 to the file GCM6.scid. Service: ta | 2016-04-13 16:51:42 HD Request # 38 | Download start Date-Time: 2016-04-05 14:27:38.000 | 2016-04-13 16:51:42 HD Request # 38 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:51:42 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:51:42 Socket (76) | Shutdown and closed. | 2016-04-13 16:52:02 HD Request # 38 | Error downloading historical Intraday data for GCM6. The network socket has been closed. Retrying download. | 2016-04-13 16:52:02 HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCM6 | 2016-04-13 16:52:02 HD Request # 39 | Downloading Intraday chart data for GCM6 to the file GCM6.scid. Service: ta | 2016-04-13 16:52:02 HD Request # 39 | Download start Date-Time: 2016-04-05 14:27:38.000 | 2016-04-13 16:52:02 HD Request # 39 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:52:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:52:02 Socket (77) | Shutdown and closed. | 2016-04-13 16:52:22 HD Request # 39 | Error downloading historical Intraday data for GCM6. The network socket has been closed. Retrying download. | 2016-04-13 16:52:22 HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCM6 | 2016-04-13 16:52:22 HD Request # 40 | Downloading Intraday chart data for GCM6 to the file GCM6.scid. Service: ta | 2016-04-13 16:52:22 HD Request # 40 | Download start Date-Time: 2016-04-05 14:27:38.000 | 2016-04-13 16:52:22 HD Request # 40 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:52:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:52:22 Socket (78) | Shutdown and closed. | 2016-04-13 16:52:42 HD Request # 40 | Error downloading historical Intraday data for GCM6. The network socket has been closed. Retrying download. | 2016-04-13 16:52:42 HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCM6 | 2016-04-13 16:52:42 HD Request # 40 | Receiving Intraday data for GCM6 starting at 2016-04-13 16:48:04 | 2016-04-13 16:52:42 HD Request # 40 | Timestamp of first Intraday data file record written: 2016-04-13 16:48:04 | 2016-04-13 16:52:42 Added 56 Time and Sales records to Intraday data file for GCM6 after download. | 2016-04-13 16:52:42 HD Request # 40 | Intraday download COMPLETE for GCM6. Completion time: 20s. Unique request ID: 25 | 2016-04-13 16:52:42 Removed historical data download ID 25 | 2016-04-13 16:52:42 Real-time Intraday chart data file updates started for GCM6 | 2016-04-13 16:52:42 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\GCM6.scid | 2016-04-13 16:52:42 Intraday chart data file opened for GCM6 | 2016-04-13 16:52:42 HD Request # 41 | Downloading Intraday chart data for CLk6 to the file CLk6.scid. Service: ta | 2016-04-13 16:52:42 HD Request # 41 | Download start Date-Time: 2016-04-13 16:43:29.000 | 2016-04-13 16:52:42 HD Request # 41 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:52:42 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:52:42 Socket (79) | Shutdown and closed. | 2016-04-13 16:53:02 HD Request # 41 | Error downloading historical Intraday data for CLk6. The network socket has been closed. Retrying download. | 2016-04-13 16:53:02 HD Request # 41 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLk6 | 2016-04-13 16:53:02 HD Request # 42 | Downloading Intraday chart data for CLk6 to the file CLk6.scid. Service: ta | 2016-04-13 16:53:02 HD Request # 42 | Download start Date-Time: 2016-04-13 16:43:29.000 | 2016-04-13 16:53:02 HD Request # 42 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:53:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:53:02 Socket (81) | Shutdown and closed. | 2016-04-13 16:53:22 HD Request # 42 | Error downloading historical Intraday data for CLk6. The network socket has been closed. Retrying download. | 2016-04-13 16:53:22 HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLk6 | 2016-04-13 16:53:22 HD Request # 43 | Downloading Intraday chart data for CLk6 to the file CLk6.scid. Service: ta | 2016-04-13 16:53:22 HD Request # 43 | Download start Date-Time: 2016-04-13 16:43:29.000 | 2016-04-13 16:53:22 HD Request # 43 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:53:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:53:22 Socket (82) | Shutdown and closed. | 2016-04-13 16:53:42 HD Request # 43 | Error downloading historical Intraday data for CLk6. The network socket has been closed. Retrying download. | 2016-04-13 16:53:42 HD Request # 43 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLk6 | 2016-04-13 16:53:42 HD Request # 43 | Receiving Intraday data for CLk6 starting at 2016-04-13 16:44:55 | 2016-04-13 16:53:42 HD Request # 43 | Timestamp of first Intraday data file record written: 2016-04-13 16:44:55 | 2016-04-13 16:53:42 Added 289 Time and Sales records to Intraday data file for CLK6 after download. | 2016-04-13 16:53:42 HD Request # 43 | Intraday download COMPLETE for CLk6. Completion time: 20s. Unique request ID: 26 | 2016-04-13 16:53:42 Removed historical data download ID 26 | 2016-04-13 16:53:42 Real-time Intraday chart data file updates started for CLK6 | 2016-04-13 16:53:42 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\CLK6.scid | 2016-04-13 16:53:42 Intraday chart data file opened for CLK6 | 2016-04-13 16:53:42 HD Request # 44 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-04-13 16:53:42 HD Request # 44 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:53:42 HD Request # 44 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:53:42 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:53:42 Socket (83) | Shutdown and closed. | 2016-04-13 16:54:02 HD Request # 44 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2016-04-13 16:54:02 HD Request # 44 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-04-13 16:54:02 HD Request # 45 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-04-13 16:54:02 HD Request # 45 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:54:02 HD Request # 45 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:54:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:54:02 Socket (84) | Shutdown and closed. | 2016-04-13 16:54:22 HD Request # 45 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2016-04-13 16:54:22 HD Request # 45 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-04-13 16:54:22 HD Request # 46 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-04-13 16:54:22 HD Request # 46 | Download start Date-Time: 2016-04-13 13:40:42.000 | 2016-04-13 16:54:22 HD Request # 46 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:54:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:54:22 Socket (85) | Shutdown and closed. | 2016-04-13 16:54:42 HD Request # 46 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2016-04-13 16:54:42 HD Request # 46 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2016-04-13 16:54:42 HD Request # 46 | Intraday download COMPLETE for TICK-NYSE. Completion time: 20s. Unique request ID: 27 | 2016-04-13 16:54:42 Removed historical data download ID 27 | 2016-04-13 16:54:42 Real-time Intraday chart data file updates started for TICK-NYSE | 2016-04-13 16:54:42 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\TICK-NYSE.scid | 2016-04-13 16:54:42 Intraday chart data file opened for TICK-NYSE | 2016-04-13 16:54:42 HD Request # 47 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:54:42 HD Request # 47 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:54:42 HD Request # 47 | Using server: ds5.sierracharts.com port 10149 | 2016-04-13 16:54:42 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2016-04-13 16:54:42 Socket (86) | Shutdown and closed. | 2016-04-13 16:55:02 HD Request # 47 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:55:02 HD Request # 47 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:55:02 HD Request # 48 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:55:02 HD Request # 48 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:55:02 HD Request # 48 | Using server: ds4.sierracharts.com port 10149 | 2016-04-13 16:55:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2016-04-13 16:55:02 Socket (88) | Shutdown and closed. | 2016-04-13 16:55:22 HD Request # 48 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:55:22 HD Request # 48 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:55:22 HD Request # 49 | Downloading Intraday chart data for CLj6 to the file CLj6.scid. Service: ta | 2016-04-13 16:55:22 HD Request # 49 | Download start Date-Time: 2016-03-15 14:08:55.000 | 2016-04-13 16:55:22 HD Request # 49 | Using server: ds3.sierracharts.com port 10149 | 2016-04-13 16:55:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2016-04-13 16:55:22 Socket (89) | Shutdown and closed. | 2016-04-13 16:55:42 HD Request # 49 | Error downloading historical Intraday data for CLj6. The network socket has been closed. Retrying download. | 2016-04-13 16:55:42 HD Request # 49 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLj6 | 2016-04-13 16:55:42 HD Request # 49 | Intraday download COMPLETE for CLj6. Completion time: 20s. Unique request ID: 28 | 2016-04-13 16:55:42 Removed historical data download ID 28 | 2016-04-13 16:55:42 Real-time Intraday chart data file updates started for CLj6 | 2016-04-13 16:55:42 Opened cached Intraday file: C:\SierraChart\SierraChartTransActMA\Data\CLj6.scid | 2016-04-13 16:55:42 Intraday chart data file opened for CLj6 | 2016-04-13 16:55:42 |
[2016-04-13 23:12:14] |
This is the relevant message: HD Request # 2 | Error downloading historical Intraday data for ESM6. The network socket has been closed. Retrying download. | 2016-04-13 16:15:23 This appears to be caused by a firewall or port blocking. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#ErrorDownloadingDataSCHistoricalDataServer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-13 23:12:24
