Date/Time: Fri, 27 Dec 2024 15:45:37 +0000
Lock the graph
View Count: 870
[2016-04-13 19:06:06] |
ibabeos1 - Posts: 6 |
Hello everybody, I want to know if its possible to "lock" the price at a place we define. I mean, on this screenshot we can see the right graph, the price is at the right of the window. On the left graph, the price is in the middle of the graph. I want to know how we can lock the graph in the middle, like the left grah, without manually place like it |
question sierra.PNG / V - Attached On 2016-04-13 19:05:26 UTC - Size: 85.38 KB - 271 views |
[2016-04-13 23:03:44] |
You need to set the Scale Range for the main price graph to "Constant Range": https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-13 23:12:53
[2016-04-14 13:25:28] |
thanks for your answer, i'm already on constant range and it doesn't work. When i place the last bar in the middle of the graph, the next bars is not in the middle. If i wait, the last bar is on the right of the window. I want the last bar every time on the middle of the graph but i dont know how to do
[2016-04-14 18:21:44] |
Do not do this. You are offsetting the scale which will affect the display of other bars. You need to let the Constant Range scale handle this automatically.Select Chart >> Reset Scales to reset the scale back to a default. Open the Scale Window: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowMainPriceGraph There is a list box containing different Constant Range Scale Modes. Set it to: Re-Center To The Last Bar On Every Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
