Date/Time: Fri, 27 Dec 2024 16:40:58 +0000
Question about ADR-NYSE chart
View Count: 996
[2016-04-13 18:49:33] |
User427015 - Posts: 2 |
The advance decline chart apparently shows the a/d as a ratio in the scale window.. Is there a way to just show the actual numerical difference between the two, i.e. 1500 or 1777 more advances than declines or vice versa as the case may be. Thanks, Lowell Blum |
[2016-04-13 19:11:37] |
You need to use this symbol: NISS-NYSE
