Date/Time: Fri, 27 Dec 2024 15:39:28 +0000
Sierra Chart Real-Time and Historical Exchange Data Feed
View Count: 911
[2016-04-13 17:20:05] |
MackenTosH11 - Posts: 13 |
Hey. Probably a dumb question but I wonder if I buy the: Sierra Chart Real-Time and Historical Exchange Data Feed. What do I have to add to access data(numbers bars)for Stocks in the Nasdaq (Apple inc and more... ) Am i right with :U.S. Equities (NYSE, NASDAQ, AMEX, BATS): Price 10.5 USD/month ? Thanks in advance |
[2016-04-13 17:30:30] |
Yes this is correct: U.S. Equities (NYSE, NASDAQ, AMEX, BATS): Price 10.5 USD/month ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-13 18:02:47] |
Just bought one month and now trying to buy the data feed: (US Equities) But when I try it say: Failed to activate the 'U.S. Equities (NYSE, NASDAQ, AMEX, BATS)' exchange. To enable the exchange at least one Real-time data connection account is required Didnt I just bought the real-time data Connection? |
[2016-04-13 18:09:48] |
The data feed is 35 USD per month plus exchange fees. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-13 18:10:05
[2016-04-13 18:19:35] |
So I just bought the software? Its $34 for the Software +$35 for the data feed + $10 for the US Equities ?
[2016-04-13 18:22:24] |
Yes that is correct. What you paid for is not just software. There are some included data services as well but not the real-time data from exchanges. What is included with the service packages is documented here: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-13 18:33:28] |
okey. Try to activate the data feed but it say I need a Futures broker? I dont have any and not interesting in this..... DO I really need all this? All I want is to get numbersbars on a couple of stocks in Nasdaq.... |
[2016-04-13 18:44:41] |
You do not need a futures broker for the US Equities exchange. We have set the futures broker in your case to "Do not need CME/CBOT/NYMEX/COMEX " And have clarified this for future users. The minimum price is 35 USD for the data feed no matter how many symbols you require. For an independent data feed, this is the lowest price data feed available. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-13 18:53:31] |
Thanks for the fast support. Will try get it work tomorrow |
[2016-04-13 19:03:13] |
Actually just realized that the Sierra Chart Exchange Data Feed has an offer where you can get it for two weeks for just 5 USD. So for the first couple of weeks it will be minimal cost. You will see that option on the page to activate it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
