Date/Time: Fri, 27 Dec 2024 16:32:41 +0000
User Question
View Count: 831
[2016-04-12 16:06:06] |
Sierra Chart - Max - Posts: 5770 |
I can help please, I have datafeed from Barchart, but data in Sierra Chart is not active. I have not in chart symbol (M). Thank you for help.
Sierra Chart Support |
[2016-04-12 17:35:00] |
Restart Sierra Chart, open a chart and provide a copy of the Message Log by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog If you are not logged into this Support Board to post a message, you can do that at the top right of this page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-12 17:35:22
[2016-04-13 09:22:25] |
User433703 - Posts: 3 |
I can help please, I have datafeed from Barchart, but data in Sierra Chart is not active. I have not in chart symbol (M). Thank you for help. Jiri Pribyl
[2016-04-13 17:45:32] |
Make sure you are connected to your trading account from Sierra Chart. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices If you still have a problem, then post a copy of the Message Log by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-14 08:54:51] |
I have new problem, I canĀ“t subscribe to Sierra Chart in my PC. I have message: "HTTP Error. Failed to establish a connection for the request. " Please help me. Thanks. Date Time Of Last Edit: 2016-04-14 10:44:43
[2016-04-14 10:34:31] |
Is this the message that you see at the Sierra Chart Login window? Refer to this page for instructions about HTTP errors: https://www.sierrachart.com/index.php?page=doc/doc_HTTPCommunicationErrors.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
