Date/Time: Sat, 28 Dec 2024 23:18:39 +0000
MISSING DATA
View Count: 1062
[2016-04-11 12:55:56]
User379468 - Posts: 508
I am missing Friday 4/10 data from 05:40 EST to Sunday 4/10 20:00. My intraday chart settings are from 18:00 to 17:00, and days to load set at 14, and yet trying delete and re-download data from 4/8 shows in log:
Rithmic Trading | Using primary service for historical data for CLK6-NYMEX | 2016-04-11 08:51:11
HD Request # 11 | Receiving Intraday data for CLK6-NYMEX starting at 2016-04-10 20:00:01 | 2016-04-11 08:51:11
HD Request # 11 | Truncating file to starting Date-Time of 2016-04-10 20:00:01 | 2016-04-11 08:51:11
HD Request # 11 | Timestamp of first Intraday data file record written: 2016-04-10 20:00:01 | 2016-04-11 08:51:11
HD Request # 11 | Received 86674 records from 2016-04-10 20:00:01 to 2016-04-11 08:51:05 (12.9 hours) and wrote 86674 records for CLK6-NYMEX | 2016-04-11 08:51:11
Have also updated SC, restarted SC, rebooted PC, re-connected feed, reloaded charts, deleted/redownloaded data, nothing.
[2016-04-11 16:47:46]
Update the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
After that re-download the data as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart
Also, when logging into this Support Board use Help >> Support Board to use the correct account.
[2016-04-12 16:04:59]
User948528 - Posts: 108
This worked. I could not get accurate charts until you replied, poor position for a trader to be in.
What changed to cause this/how can I prevent it being an issue during the trading day?
Can you provide some kind of notice when/if this needs to be done?
Date Time Of Last Edit: 2016-04-12 16:06:04
[2016-04-12 17:03:54]
We do not know why the problem occurred but basically there were incomplete Symbol Settings for one or more symbols affecting the routing of historical data requests.
[2016-04-19 00:41:58]
Thanks, perhaps a message in the log to indicate the issue/solution could be helpful in the future.
[2016-04-26 11:47:51]
This problem is occurring again for me, on v1400, and the original instructions above are not resolving it either in the main or sub-instance. This time it is for NGM6 from 4/25 21:25 to 4/26 7:25. There does not appear to be any indication in either log.
[2016-04-26 16:47:53]
Since the weekend there has been some limitations with the Rithmic historical data.
Historical data for NGM6 is now available.
Follow the instructions here:
[2016-04-26 19:39:46]
Can you clarify what is the new limitation?
And is there any way to prevent these missing data issues during the trading day?
[2016-04-26 20:06:10]
We are going to solve the data limitations by the end of the day.
We will not go into details. It is an internal technical problem.
This is not a normal case and is highly unusual. You will not have a problem effective after the close of the market today.
Date Time Of Last Edit: 2016-04-26 20:06:24
[2016-05-04 02:10:32]
Problem occurring yet again today 5/3/16 on v1403 Rithmic, 6JM6 19:15 to 20:00.
Do I need to go through and check every symbol to make sure it is fixed on each?
Symbol NIY data also seems to not be working. Looks like a different issue.
Date Time Of Last Edit: 2016-05-04 02:56:55
[2016-05-04 03:03:01]
This is now solved. You do not need to look at any others. There was a specific reason why there was missing data for this contract and is permanently solved.
Follow the instructions here to download the missing data:
[2016-05-04 03:08:34]
Actually, there are some additional steps we have to take before the data is fully restored.
Give us a few more minutes.
