Date/Time: Tue, 04 Aug 2026 06:53:14 +0000
Backtesting
View Count: 1140
| [2016-04-11 06:20:51] |
| User134797 - Posts: 56 |
Hi All, I what to backtest a trading strategy for example: - Buy voor 7000 Eur ING stocks, one stock cost 10 Eur. - Sell if the stock 0.12 Eur cents higher. - Buy when 3 SME is above 5 SME is above 8 SME. I already create the alert trigger. How to work out this example from the start Note: I already try the "Auto trade system replay back test. the replay is working bud if I go to the "Trade activity Log" I do not ING in ALL Symbols part. Best Regards, IWan |
| [2016-04-11 07:18:20] |
| enemyspy - Posts: 307 |
did you actually construct the trading system via spreadsheets or acsil? or did you just set an alert?
| [2016-04-11 08:10:55] |
Hi All, I set the Alert, I did not use spreadsheets and I use chart studies for the technical indicaotr trigger. I can see in the alert manager the triggers popsup. I what backtest if there is a example Iam glad. Best, Iwam |
| [2016-04-11 08:16:55] |
That will show you the trading signals, but in order to make it take simulated trades you to make it a trading system. Take a look at the spreadsheet system for trading in the help files. Similar kind of syntax as it is to programming the alerts. Not too hard to use.
| [2016-04-11 10:35:07] |
This question is not within the scope of our support. We can only refer you to the relevant documentation: Automated Trading Management Auto Trade System Back Testing But as has been said, you do have to create a trading system using either the Spreadsheet System for Trading study or the Advanced Custom Study Interface and Language(ACSIL). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-11 10:36:20
