Date/Time: Fri, 27 Dec 2024 01:25:33 +0000
Stats On Bar
View Count: 621
[2016-04-10 00:11:52] |
Rithmic - Posts: 18 |
When I'm using the line or ray tool I'm accustomed to being able to place the cursor on a bar and receive lots of stats on that bar: high, low, close, opening date and time etc. I have just downloaded the most recent version of SC and I am no longer getting the stats that I need. What do I have set incorrectly. Thank you.
[2016-04-10 00:32:21] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#UseCompactToolValuesWindowEquivalentOldStatusBar (Instructions to Use Compact Tool Values Window Equivalent to Old Status Bar) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-10 00:36:18] |
Additionally, You will want to select Global Settings >> Tool Settings >> Chart Values and select this from the list box containing this option: Always On When Using Other Tools.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-10 00:36:48
