Date/Time: Fri, 27 Dec 2024 00:21:12 +0000
[User Discussion] - Problem in loading mutual data from Google Financial Data Source
View Count: 673
[2016-04-09 16:52:38] |
User650425 - Posts: 2 |
When load mutual data from Google, e.g. JARTX-MULT, the screen showed "Historical Data Download completed", but the chart is still blank. No problem for stock data like "MSFT-NASDAQ", it loaded instantly, so I think the connection is fine, but problem with mutual fund data. Please help for downloading mutual data from Google. |
[2016-04-09 22:36:24] |
We do not provide any support for this.
[2016-04-10 00:10:54] |
For mutual funds use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
