Date/Time: Wed, 09 Sep 2026 14:28:07 +0000
Number Bars CandleStick Body Outline using renko charts
View Count: 3142
| [2016-04-09 01:57:43] |
| apollofl - Posts: 95 |
On a regular renko candlestick chart, wicks are shown, but using Number Bars renko Candle Stick Body Outline on some bars wicks aren't shown. For an example On 1 bar using the regular renko chart it had a 5 tick wick, but on that same bar on the number bar renko, it had only a 1 tick wick. help please. Thanks http://www.sierrachart.com/image.php?Image=1460169286373.png http://www.sierrachart.com/image.php?Image=1460169421549.png Renko Bars With Wicks Date Time Of Last Edit: 2016-04-09 02:47:35
| [2016-04-09 02:04:27] |
This is not clear for us. How are you setting this: Candle Stick Body Outline? Also post chart images following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Do not use any other method to post a chart image. Only this method. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-09 11:21:43] |
Here's the file http://www.sierrachart.com/image.php?Image=1460200739385.png http://www.sierrachart.com/image.php?Image=1460200793591.png Renko bars with wicks |
| Attachment Deleted. |
| [2016-04-09 13:39:49] |
This is not completely clear but we think we understand it and this will be added to the next release: The new Numbers Bars Open and Close Marker Style >> Candlestick Body* settings will support the Renko Open and Close values when used with Renko bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-09 13:40:17
| [2016-04-09 15:37:08] |
Updated Information...I hope this clears it up. Thanks I Missed the Up bar lack of a wick at 8:46:56. again Thanks for All that you do. Date Time Of Last Edit: 2016-04-09 16:06:19
| [2016-04-10 00:37:31] |
We understand. This will be solved in the next release.
| [2016-04-10 16:10:38] |
Thank You Support. Well Done. |
