Date/Time: Fri, 27 Dec 2024 01:25:16 +0000
Daily profiles with visible bar option
View Count: 776
[2016-04-09 00:47:10]
User771416 - Posts: 47
i have a chart that plots the RTH activity using Flex Renko bars for the RTH period only. I'm using VbP with a period type of Multiple Profiles Based on Fixed Time, my time period is Days, the length of time is 1, the profiles are right aligned. I'd like the ability to scroll back to the beginning of the day and have the profile for that day reflect only the visible bars displayed on the chart. changing to a period type of Visible Bars does not work. Any suggestions?
[2016-04-09 00:50:18]
What does not work when you use "Visible Bars"? That should do exactly what you want or you are looking for something that is not supported.
This is too vague for us.
Date Time Of Last Edit: 2016-04-09 00:50:35
[2016-04-09 01:55:41]
What i mean when i say using visible bars doesn't work is that when you switch to visible bars you get one profile for all visible bars on the chart, which would include, at the very least, some of yesterday's activity. i want yesterday's profile to reference yesterday's activity only, or if right aligned, i suppose yesterday's profile would only reflect those bars visible on the chart if i'm in this particular viewing mode.
i have no idea if i'm asking for something that is not supported. i'm very new to Sierra.
the purpose of the request is to allow me to scroll back to the beginning of a day and see what happened, and how the profile was being developed based on what was occurring with price action. if the profile remains static based on the full day's activity, i have no way of seeing what was taking place relative to the profile early on in the session.
Thanks for taking a run at it.
[2016-04-09 02:34:57]
This is unsupported in the way that you are asking for this.
What you need to do is replay the chart:
https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html
