Date/Time: Fri, 27 Dec 2024 00:39:03 +0000
display spreadsheet cell on chart
View Count: 760
[2016-04-08 20:14:35]
User722905 - Posts: 9
Will someone please direct me to the documentation on "how to display a spreadsheet cell on a chart"?
Thank you.
[2016-04-09 09:35:43]
This does not currently exist but we will try to put this together over the weekend.
[2016-04-10 02:18:05]
Attached are the two files that you need to use for this.
These both need to be saved to the Data Files Folder
For instructions to use these, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html#UsingStudyCollection
Enter the value you want to display on the chart in cell K3. And you can use formulas to generate the value.
attachmentValueAsTextOnChart.scss - Attached On 2016-04-10 02:10:53 UTC - Size: 1.53 KB - 429 views
attachmentValueAsTextOnChart.StdyCollct - Attached On 2016-04-10 02:10:58 UTC - Size: 18.7 KB - 305 views
[2016-04-10 18:57:43]
Incredible responsiveness, another reason I've remained a loyal Sierra customer for years.
Thank you very much.
