Date/Time: Tue, 14 Jan 2025 02:15:40 +0000
Alarm and writing
View Count: 751
[2016-04-08 14:17:37] |
User625993 - Posts: 7 |
Hello, one of my client would like to set an alarm if, for example the price goes above 100 and in the same moment to have a writing on the chart about what happened. Is this possible? Thank you. |
[2016-04-08 17:40:01] |
To do this, a Symbol Alert can be used: https://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html#SymbolAlerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-08 17:44:16] |
He wants to be able to write a comment, non just to add a symbol to the chart.
[2016-04-09 09:30:31] |
We prepared a Study Collection that does this. Refer to the study collection at number 37 here: Additional Files (Study Collections, Spreadsheets, Chartbooks) Be sure to refer to the top of the page for instructions to work with that study collection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
