Date/Time: Fri, 27 Dec 2024 00:41:06 +0000
String to Integer
View Count: 1216
[2016-04-08 13:58:18] |
User53601 - Posts: 105 |
Hello, In ACSIL, is there a way to convert string value to integer value? string value to long value? thank you |
[2016-04-08 17:50:53] |
Use the atoi function.
