Date/Time: Fri, 27 Dec 2024 01:26:24 +0000
New to sierra charts
View Count: 770
[2016-04-08 11:25:44] |
hatem hosny - Posts: 57 |
hi, -I can not read bar price values. i put my cursor to a certain bar, i can not read (high, low, ...)! - i read the help documents but i could not find anything. thank you for helping, Date Time Of Last Edit: 2016-04-08 13:52:53
[2016-04-08 13:54:51] |
- Is anyone know how? i think it is a simple question
[2016-04-08 18:00:42] |
1. You need to use the Chart Values tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-08 18:44:37] |
sir, i want to just pointing to a certain column or a bar to view its price values immediately without opening such value windows!!.just like any other software (MT4). |
[2016-04-08 22:44:27] |
There is also the Compact Tool Values Window: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CompactToolValuesWindow This one opens automatically as is documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
