Date/Time: Sun, 27 Sep 2026 23:14:46 +0000
2 sierra on same computer...
View Count: 964
[2016-04-08 10:34:00]
User52247 - Posts: 26
Is it possible to have 2 Sierra charts with two differents brokers on the same computer?
Example: I would like to have on the same computer: Nasdaq with account X and Eurostoxx with account Y
If it's possible how can I do? What is the best solution?
Thank you for your answer,
ad101166
[2016-04-08 10:54:20]
Yes, you can do this.
Refer to this page:
Using Multiple Data and Trading Services at the Same Time
