Date/Time: Fri, 27 Dec 2024 00:19:40 +0000
TPO settings
View Count: 746
[2016-04-07 19:47:09] |
AC69294 - Posts: 1 |
what should the settings be in TPO Chart setting. my candles disapear Thank you |
[2016-04-07 20:06:25] |
A TPO Profile Chart study will remove the standard chart bars/candlesticks.
