Date/Time: Fri, 27 Dec 2024 00:52:05 +0000
NB Calc Values - SG30 Bar Duration
View Count: 686
[2016-04-07 18:12:33] |
infpz - Posts: 826 |
How do I refer to this as part of an alert condition? For example color background when bar duration is less than 30 seconds? i.e., ID1.SG30<??? |
[2016-04-07 18:54:18] |
We updated the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#SubgraphDescriptions Refer to the description for Bar Duration. Reload the page for the updated content. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-07 18:55:00
