Date/Time: Mon, 05 Oct 2026 04:14:09 +0000
Up/Down Volume Difference By Tick With Filters
View Count: 2101
[2016-04-07 17:44:39]
User15378 - Posts: 45
Hi there, if anyone has a idea what the difference is between data options int he settings of the following:
Up/down volume
Ask/bid volume
i see it makes slight changes but curious to see the difference.
Thanks very much
[2016-04-07 20:16:31]
bjohnson777 (Brett Johnson) - Posts: 284
They are similar. The reason I switched to "Ask/Bid Volume" as default was that "Intraday Data File Compression" breaks "Up/Down Volume" if it is used.
http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php#HistoricalBidAskVolume
Bid Volume and Ask Volume represent the volume actually traded at the Bid or Ask respectively.
I also found another reference in the docs that should apply mentioning at bid price or lower and at ask price or higher.
And quick add from the programming docs:
Down Volume:
This array contains the total volume of trades for the bar where the trades occurred at a lower price than the trade before or the symbol traded at the same price as before and previously it traded down.
Up Volume:
This array contains the total volume of trades for the bar where the trades occurred at a higher price than the trade before or the symbol traded at the same price as before and previously it traded higher.
Date Time Of Last Edit: 2016-04-07 20:26:28
[2016-04-08 16:25:24]
Thanks very much for the info cheers!
