Date/Time: Fri, 27 Dec 2024 00:46:52 +0000
trial
View Count: 665
[2016-04-07 17:26:15] |
User472677 - Posts: 356 |
hello, I am seriously thinking of switching to your software. I had a trial before but did not get time to answer my questions. Now I can either ask you lots of questions or you can allow me a new 30 day trial so I can answer my questions. Please give me a new 30 day tria, it will be easier for everone. |
[2016-04-07 17:49:34] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
