Date/Time: Fri, 27 Dec 2024 00:58:37 +0000
Two accounts under same login for T4
View Count: 830
[2016-04-07 04:25:39]
KhaosTrader - Posts: 128
If I have 2 accounts under T4 under the same login, how do I switch back and forth between accounts? What are my options for trading 2 accounts with one T4 login?
Thanks in advance.
[2016-04-07 04:37:02]
Also, another question, could I have two different logins on the same computer at the same time. Would this be preferable with T4?
[2016-04-07 04:41:43]
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SelectingTradeAccount
You do not want to use two separate logins to T4. That is definitely not preferable.
