Date/Time: Fri, 20 Sep 2024 00:55:54 +0000
CCU3 intraday missing
View Count: 1346
[2013-07-05 22:12:59] |
Paul.M - Posts: 113 |
CCU3 intraday missing via SC Historical Intraday Futures data. Please correct this. Am I the only one ? I had to request so many symbols by now. |
[2013-07-05 22:22:29] |
Data for that symbol is not available at all with that service. Instead, you need to use this service: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-05 22:22:46
