Date/Time: Fri, 27 Dec 2024 01:16:57 +0000
New customer needs info...
View Count: 1373
[2016-04-06 21:19:24] |
Rog1972 - Posts: 2 |
I am trying your free 30 trial currently. I currently have etrade Pro and I like there data platform but they do not have one of the studies that I need. Your system does have it and I currently am using it. I need to know if there is a way to use your service with real time quotes but keep my etrade pro for my trades? If it is possible to know how to change brokers please let me know the cost of doing this. Thanks, Roger Swaim |
[2016-04-07 04:08:06] |
You can use the Sierra Chart Exchange Data Feed for real-time data: Sierra Chart Exchange Data Feed Another possibility is to change brokers as you mentioned. Do you trade futures or stocks or Forex? There is no cost to change a broker. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-07 12:13:48] |
Only stocks to this point. With the real time data for stocks plus exchange fees what would be my cost if I keep my brokerage at eTrade Pro? Sorry for the questions I am somewhat new at this. Love your charting though. Roger |
[2016-04-07 17:45:51] |
The cost will be 35 USD per month for the data feed + 10.5 USD per month for the exchange fee. This is in addition to what you pay for Sierra Chart. If you want to change brokers, the only reasonable choice with consideration to commissions would be Interactive Brokers: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-07 17:46:21
