Date/Time: Sat, 11 Jan 2025 07:06:15 +0000
Woodies Studies
View Count: 1439
[2016-04-06 20:36:59]
User937866 - Posts: 12
I am interested in the Woodies ZLR System study and see it is under additional files. Is it a free add-on or is there a charge. If I would like to add it do I simply download the file from the Sierra Chart website?
[2016-04-07 06:27:25]
You can find the Woodies Study Collection here:
Additional Files (Study Collections, Spreadsheets, Chartbooks)
Have a look at this Support Board posting:
https://www.sierrachart.com/supportboard/showthread.php?t=17649
We have not done any development with this for years and we do not provide support for it.
[2016-11-10 11:36:43]
vtrader - Posts: 3
Hello, Support !
I am struggling to get the zlr displayed.
I am ttaching a screenshot - studies are added, but zlr is not displayed. Could you assist with this please ?
imagezlr not shown.PNG / V - Attached On 2016-11-10 11:35:59 UTC - Size: 63.46 KB - 280 views
[2016-11-10 17:43:48]
Make sure you use one of the Woodies Study Collections found on this page:
http://www.sierrachart.com/index.php?page=doc/AdditionalFiles.php
This will apply the studies with the proper configuration.
[2016-11-11 06:44:45]
vtrader - Posts: 3
Well, this was done long time ago - here is the screenshot
As you can see , studies are saved in the "data" folder, I have restarted Sierra chart after that and still nothing is displayed.
Would you know why ?
imagestudies.PNG / V - Attached On 2016-11-11 06:43:32 UTC - Size: 25.65 KB - 265 views
[2016-11-12 01:31:32]
We have determined that the Woodies Study Collection files are properly configured.
You actually need to apply one of them to the chart following the instructions here:
https://www.sierrachart.com/index.php?page=doc/DLLUsage.html#UsingStudyCollection
[2016-11-13 15:52:22]
vtrader - Posts: 3
I have followed these instrutions and nothing is displayed when Woodied ZLR study is applied.
Is there any way to find out why ? Could you recommend any logs to review etc ? How can I check why the study is not working properly ?
[2016-11-13 22:26:17]
What you need to do is go to the Analysis menu on the main window Sierra Chart and then directly from that menu you need to select Woodies for Range Charts.
This is the only proper way to apply those studies to the chart due to the complex configuration.
Date Time Of Last Edit: 2016-11-13 22:26:31
