Date/Time: Fri, 27 Dec 2024 00:50:03 +0000
show orders fill error in windows 10
View Count: 741
[2016-04-06 17:00:35] |
User992517 - Posts: 1 |
I cannot see any entry exit connecting lines or mark when I check show orders fill in windows 10 Can't I use show orders fill function in windows 10? I trade E mini S&P futures Show orders function work well when I use windows 7 Date Time Of Last Edit: 2016-04-06 17:06:29
[2016-04-06 19:20:00] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Whatever the issue is, it is not affected by the operating system version. That would not even be possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-06 19:20:22
