Date/Time: Mon, 12 Oct 2026 18:14:03 +0000
volume per bar
View Count: 1289
| [2016-04-06 14:11:12] |
| User771416 - Posts: 47 |
i'm plotting an ES daily chart with a composite volume profile and i'm having two issues. i cannot seem to change the 'volume per bar' in the settings from the default of 5 to a lower number. i can change it to a higher number, but i cannot lower it. can you tell me why? Also, on the same chart, i cannot 'draw' a volume profile (trying to draw a micro composite around a group of days). the selection Tools>Draw Volume Profile is grayed out. |
| [2016-04-06 19:09:06] |
Refer to the documentation for this setting here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#Settings The Tools >> Draw Volume Profile tool does require service package 5 and we see you are using that. If that menu command is still disabled, restart Sierra Chart in case the service package was recently changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
