Date/Time: Fri, 27 Dec 2024 00:54:20 +0000
Additional Daily Bar when using intraday data - ES 24h Session
View Count: 1125
[2016-04-06 10:26:37]
User985778 - Posts: 16
Hi all,
can you tell me what the problem is with my settings?
Why do I get the additional bar on the chart?
I am trying to plot the 24 h session for the ES as daily bars with the Chicago Time Zone setting.
Please see screenshots
Thanks a lot!
imagechart.PNG / V - Attached On 2016-04-06 10:25:48 UTC - Size: 129.68 KB - 240 views
imagetime zone setting.PNG / V - Attached On 2016-04-06 10:25:52 UTC - Size: 42.28 KB - 268 views
[2016-04-06 18:53:23]
With those settings you will get an additional bar for Friday.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#FilteringOutFridayEveningData
[2016-04-08 11:43:58]
Thank you very much!
