Date/Time: Wed, 23 Sep 2026 07:10:07 +0000
size/length of the SCString variable
View Count: 1167
| [2016-04-05 20:49:54] |
| User53601 - Posts: 107 |
Seems to be very simple task, but I cannt find out the code for size/length of the SCString variable. I tried this code: SCString Header ; int StringLength = Header.size; but the result is: error: 'class SCString' has no member named 'size' could you pls help. |
| [2016-04-05 23:26:20] |
You need to use: SCString::GetLength() The documentation will be updated if this does not already exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
