Date/Time: Fri, 27 Dec 2024 00:33:56 +0000
Attaching orders to indicators
View Count: 1148
[2016-04-05 19:25:53] |
EuropeanTrader - Posts: 290 |
Hello, is it possible to attach orders to indicators? Thank you. |
[2016-04-06 05:59:06] |
Yes indirectly. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#StudyControlledTargetsStops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-08 19:07:58] |
This is awesome. Thank you. I will take a deeper look into this.
