Date/Time: Mon, 28 Sep 2026 20:16:03 +0000
User Email
View Count: 899
[2016-04-05 19:20:35]
Sierra Chart - Max - Posts: 5971
Hi,i need help with two things one in establishing the control bar on my charts ,please show me the way to install the control bar as currently it does no appear on the charts
and two the moving off the charts up and down which is done by pressing the left cursor and scrolling on the right end over the numbers i can’t do it currently
1. To enable the Control Bar select Window >> Control Bars >> Control Bar 1 (or any other number that you have setup).
For further details, refer to the documentation here:
Window, CB and CW Menus: Control Bars >> Control Bar [1-8] (Window)
Global Settings Menu: Customize Control Bars >> Control Bar 1-12 (Global Settings menu)
2. It sounds like you are describing the Interactive Scale Move functionality. Refer to the documentation here:
Chart Scale and Scale Adjusting: Interactive Scale Move - Move Scale Up and Down
Sierra Chart Support
Date Time Of Last Edit: 2016-04-06 00:31:29
