Date/Time: Fri, 27 Dec 2024 15:52:45 +0000
cd for forex spot ?
View Count: 1106
[2016-04-05 16:58:03]
User256583 - Posts: 5
sir , As u know that there is no real volume in FOREX So normally they substitute REAL VOLUME by TICK VOLUME in FOREX case .. do sierrachart support CD (Cumulative Delta) for forex pairs ? i.e. : can sierrachart draw CD for forex pairs ? if so, based on what does sierrachart draw CD for FX pairs ? What is the principles u follow in to draw CD for FOREX pairs ?
2nd thing : can you explain the diffrence in sierrachart calculation of CD between euro future (CME) AND eur/usd (spot) ? how does CD caulculation differ in these cases ?
Which forex datafeed you prefer for drawing CD in FX pairs (spot not futures) which provide a big bulk of past tick data ( tick data for past say 60 days ) ? which best datafeed provider do u advice for drawing CD in FX pairs which provide bulk past tick data and is truly compatible with sierrachart ?
[2016-04-05 17:18:13]
All of your questions are answered in these particular sections:
https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#VolumeData
https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#BidVolumeAskVolume
https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Definitions
Cumulative Delta Bars is supported with Forex data.
Have a look at using LMAX for spot Forex data and trading:
LMAX Trading Service
Date Time Of Last Edit: 2016-04-05 17:18:42
[2016-04-06 02:29:23]
ok , may i check its reliability ? may i get a trial ?
cuz i'v tried same LMAX with other platform CD , but it was a mess ! I'm afraid that the datafeed itself is not reliable.
[2016-04-06 05:21:00]
Your account has been activated and/or reset.
A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
Your LMAX trading account has now been assigned to your Sierra Chart account.
Refer to this page and confirm the account number is correct:
https://www.sierrachart.com/usercp.php
Update Sierra Chart to the current version following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
Set "Global Settings >> Data/Trade Service Settings >> Service" to "LMAX Demo Trading - DTC".
Connect to the server with "File >> Connect to Data Feed".
Depending upon when you receive this message it may take up to two minutes for our server to receive the updated authorizations for you to be able to connect.
The demo is valid for two weeks after which time, it will be disabled.
Date Time Of Last Edit: 2016-04-06 05:21:17
[2016-04-06 12:26:15]
Thanx sir
1- in the data/trade service settings >> is the (SC Data - all services data) free when i subscribe after the demo trial ? shall i pay for this datafeed or it come free when i subscribe ? I know it is delayed for about 20 minutes and no issue for this delay.
2- How can i setup a free trial for CQG datafeed now with my demo now ?
Thanx
[2016-04-06 18:00:15]
1. For markets which are not provided in real time unless you are using the Sierra Chart Exchange Data Feed, there is only historical data and it is delayed. If that is acceptable, then what you have access to now will be included.
2. Refer to:
CQG Trading Platform Service
[2016-04-13 10:17:49]
ok sir
i see that sierrachart provide cumulative delta volume.
but do SC provide delta candles bar by bar basis ( not accumulated ) like in attached screen shot ?
imagedelta.png / V - Attached On 2016-04-13 10:17:46 UTC - Size: 83.27 KB - 250 views
[2016-04-13 17:19:46]
Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar
There is Bar Period Type >> Delta Volume Per Bar.
[2016-04-13 19:13:18]
sir i don't want to draw delta volume per bar
i want to get seperate delta candles below original chart that shows delta
[2016-04-13 20:09:33]
We think you are looking for this study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s291
