Date/Time: Fri, 27 Dec 2024 01:16:50 +0000
Numbers bars showing zeros after download
View Count: 672
[2016-04-05 14:00:23] |
User219142 - Posts: 1 |
Using Rithimic Numbers bars showing zeros after download |
[2016-04-05 16:09:06] |
You need to update to the current version of Sierra Chart following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate After that follow the procedure here to re-download the data: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-05 16:09:59
