Date/Time: Fri, 27 Dec 2024 00:39:16 +0000
set_window
View Count: 633
[2016-04-05 10:31:33] |
User850017 - Posts: 41 |
Hello, what I have to set for windows? I want to set USD.CZ like another chart. Without upper panel. THX |
siera_set.png / V - Attached On 2016-04-05 10:31:27 UTC - Size: 40.39 KB - 236 views |
[2016-04-05 16:42:56] |
This can be done through Chart >> Show Title Bar: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#ShowTitleBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
