Date/Time: Fri, 27 Dec 2024 01:07:31 +0000
Eurex feed
View Count: 668
[2016-04-05 06:25:33] |
DEA1 - Posts: 47 |
Hi. I'm not getting Eurex data this morning. Exchange seems okay, problem your end? Thanks.
[2016-04-05 06:30:48] |
Yes. There is a problem with the Barchart source data feed. Barchart operations has been notified and told it is urgent. We are looking to switch to a backup EUREX data feed. But that probably will take us a couple of hours to get that out. And by then the Barchart data feed should be back again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
