Date/Time: Fri, 20 Sep 2024 00:50:31 +0000
order - Buy Stop Limit
View Count: 1304
[2013-07-05 15:12:48] |
fspisem1 - Posts: 12 |
Could you confirm which points are true and what is not true? 1) When using a buy stop limit, the stop have to be ABOVE the current market price and limit can be LOWER than current market price. 2) When using a buy stop limit both the stop and the stop limit price have to be ABOVE the current market price. 3) When using a buy stop limit order it can be executed ONLY with specific limit price or LESS than specific limit price but NEVER HIGHER than specific limit price. Thanks |
[2013-07-05 19:33:42] |
1, 2, 3. You need to contact your broker about these. These questions are there responsibility. Please update Sierra Chart with Help >> Download Current Version. There was a problem where in the most recent versions Stop-Limit orders were sent as Stop-Market orders in the case of TransAct and Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
