Date/Time: Fri, 27 Dec 2024 01:11:08 +0000
Green Charts shutting down say time has expired
View Count: 762
[2016-04-04 01:09:06] |
User912667 - Posts: 2 |
My Green Charts is continuing to shut down. The log says the time has expired. Green Charts has my credit card. Please charge the account and restore the software Immediately. This is very annoying obviously. If there is a problem with the credit card please let me know and I will get you a new one. However, I do not believe there is any problem with the credit card. Please RESPOND ASAP as I need the charts NOW> Don Armstrong |
[2016-04-04 01:22:21] |
Could you please post a copy of the Message Log following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We want to see a copy of this so we can make sure to prevent this from happening again. After this restart Sierra Chart and you should be fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-04 02:21:53] |
You will have to restart Sierra Chart at least once a month due to the kind of billing which is set up on your Sierra Chart account. However, we did see the particular reason why this occurred and that will be resolved tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
