Date/Time: Fri, 27 Dec 2024 00:46:33 +0000
OHLC BARS
View Count: 843
[2016-04-03 23:41:20]
tellerbe - Posts: 109
Is there a way to change color of OHLC bars? I would like the green to be darker so I can see it better
Date Time Of Last Edit: 2016-04-03 23:45:56
[2016-04-04 00:11:31]
Mike_S - Posts: 42
Chart - Graphics Settings - Bar High-Low Down and Bar High-Low Up.
[2016-04-04 00:26:56]
This is done through Graphics Settings:
https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html
You need to change the colors of:
Bar High-Low Down
Bar High-Low Up
Date Time Of Last Edit: 2016-04-04 00:27:09
[2016-04-05 18:25:39]
I went to Chart>>Graphic Settings>> BarHigh-Low both up and down. Tried to change color and nothing happened.
[2016-04-06 05:12:59]
You need to do this through Global Settings >> Graphics Settings.
