Date/Time: Wed, 07 Oct 2026 11:56:16 +0000
General Settings -> Files to Open on Startup does not work
View Count: 1108
| [2016-04-02 22:03:24] |
| dominikos - Posts: 106 |
This functionality does not work if files are outside Data directory. The files that I would like to open are stored in Dropbox directory since I share them between two computers. Can you consider changing it to accommodate other locations than Data? Thanks, - Dominik |
| [2016-04-02 22:24:16] |
No, this is something that we would not change.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-02 22:24:48
| [2016-04-04 11:13:28] |
I'm not questioning this decision but want to point out that 'recent file list' retains location information for chartbook files. Handling it in 'General Settings - Files Open On Startup' seems to be inconsistent.
