Date/Time: Fri, 27 Dec 2024 16:35:34 +0000
Metastock Data
View Count: 1375
[2016-04-02 19:31:23] |
User810252 - Posts: 1 |
HI, i CREATED MY ACCOUNT AND DOWNLOADED THE SOFTWARE AND STARTED IT, BUT I COULD NOT LOAD MY LOCAL DATA. I AM IN SAUDI ARABIA AND I AM TRADING ONLY GULF COUNTRIES STOCK MARKETS. LOCAL DATA PROVIDERS FEEDING METASTOCK DATA TYPE LIVE AND HISTORICAL. SO, HOW I CAN CONNECT AND LOAD METASTOCK DATA TO YOUR SOFTWARE ? AWAITING YOUR PROMPT RESPONSE PLEASE. REGARDS, MOAJEB ZAHRANI |
[2016-04-03 22:11:12] |
Sierra Chart does not support reading or using Meta Stock data. However, if the Meta Stock historical data can be exported to a text format, then Sierra Chart can read it. Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
