Date/Time: Fri, 27 Dec 2024 16:15:51 +0000
Keep Only X Number of Bars Loaded?
View Count: 680
[2016-04-01 22:27:59] |
Halco - Posts: 92 |
Is it possible to keep a constant number of bars loaded into a chart? For instance, an hourly chart with only 12 bars loaded, so as a new bar is created the first bar is dropped from the chart, so there are always only 12 bars? Thanks.
[2016-04-02 02:30:10] |
No and this capability will never be added.
