Date/Time: Fri, 27 Dec 2024 00:45:39 +0000
Need One Trial Day to Test Rithmic Login
View Count: 849
[2016-04-01 12:56:47] |
User773656 - Posts: 9 |
Hello, I'm hoping I can get one trial day to see if my new Rithmic login will work with Sierra Chart before purchasing. The account is with AMP but I'm planning on going direct to Sierra Chart for the real-time package. Please let me know if you can help with this thanks |
[2016-04-01 16:55:37] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-04-01 18:16:58] |
Thanks for the response I tried the new Rithmic login and it works fine with the trial. I'm saying this because I read other posts and didnt understand what was said regarding being charged twice from the CME. I'm trying to find out if Sierra Chart real-time feed will be available with AMP futures or not? If its not, I have to buy the direct package level 5 from Sierra Chart? The direct package level 5 and the real-time feed are separate costs? Then I would have to select which markets I want data from? (Do not select CME feed because thats my Rithmic account and was charged from AMP, right?) And all I have to do is login with my Rithmic account, select support from Sierra Chart feed on DTS, and I will be able to view/trade futures and view equities? Is there anything I'm missing? Please let me know thanks |
[2016-04-01 18:31:55] |
Yes you can now use the Sierra Chart Exchange Data Feed when you are using Sierra Chart provided by AMP, but there is an additional charge placed on it of 10 USD per month. Or you can use a direct account. It would be better to use a direct account because then you can take advantage of the long-term user discount. Service package 5 and the Sierra Chart Exchange Data Feed are separate costs. Then I would have to select which markets I want data from? (Do not select CME feed because thats my Rithmic account and was charged from AMP, right?) And all I have to do is login with my Rithmic account, select support from Sierra Chart feed on DTS, and I will be able to view/trade futures and view equities? Both of these are a correct understanding. Here are the instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-01 18:32:36
[2016-04-01 19:08:54] |
Thanks for the response I'm planning on using the "U.S. Equities (NYSE, NASDAQ, AMEX, BATS): Price 10.5 USD/month.". Does this include the actual indices (SPX, $DJI, NDX,) as well? |
[2016-04-01 19:35:23] |
No. Those are separate exchanges. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
