Date/Time: Fri, 20 Sep 2024 00:54:58 +0000
Technical possibility to program a study /strategy base on different assets ( in cpp )
View Count: 1388
[2013-07-05 11:58:37] |
Moti - Posts: 63 |
Hello, I will like to build a study that give True or False from 9 different assets ( For example the 9 S&P ETF sectors XLF.XLI.XLK.. ) If every one the ETF in 30 minutes have at least One Japanese candlestick pattern ( Engulfing OR marabuzu OR, morning star) than Alert Any limit for the number of assets in one study? Can I MIX time frames and add the same condition for 60 & 120 minutes at the same study ? Thank you, Moti |
[2013-07-05 19:49:47] |
This is supported. Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_ACSILRefOtherTimeFrames.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
