Date/Time: Fri, 27 Dec 2024 16:07:08 +0000
Chart Trading Position Lines
View Count: 638
[2016-03-31 23:13:17] |
User21113 - Posts: 62 |
Topic: Chart Trading Order Line is displayed as follows: Lmt|1000|X See the image for reference Is it possible to configure the chart trading position and target lines as follows. It is possible to only show the order quantity? 1000|X instead of Lmt|1000|X Is is possible to abbreviate the volume? 1K|X instead of 1000|X With chart trading enabled is is possible to only show the order fills? Thanks |
Order Line.JPG / V - Attached On 2016-03-31 23:06:59 UTC - Size: 9.39 KB - 262 views |
[2016-04-01 20:42:19] |
We will add to our task list, the ability to hide the order type for the order line on the chart. When chart trading is enabled, the order lines will always be displayed. There is no way to disable that. And the quantity does not use a suffix until it exceeds 10000. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
