Date/Time: Sun, 24 Nov 2024 22:55:54 +0000
Using Daily OHLC single point to plot High and Low of day for a Sine Wave WMA doesn't plot
View Count: 1374
[2016-03-31 12:17:42] |
djcurcio - Posts: 236 |
I want to plot and generate alerts for the daily high and low of a sine wave weighted MA. I have set the SWMA to Auto Coloring to Based on Slope and can see the Highs and Lows. Using the Daily OHLC single point results in no plot. Help please. Thanks |
[2016-03-31 16:42:11] |
The Daily OHLC studies cannot be based on other studies.
[2016-03-31 16:48:59] |
OK, so how to get the daily HL of the sine wave or any other study to plot and generate and alert. Please |
[2016-03-31 17:30:42] |
We are planning to add a study to do this. We hope to get to it next month .
[2016-03-31 20:37:36] |
mkata - Posts: 103 |
djcurcio, A work around that I often use for this type of thing is to use the Moving Averages study. Set two of the averages to a 1-period simple MA of your desired study and then you can use the Daily High/Low studies based on the Moving Averages study. |
[2016-03-31 21:37:33] |
thanks
[2024-04-18 13:17:47] |
User411320 - Posts: 289 |
was this ever added
[2024-04-18 13:30:06] |
Sierra_Chart Engineering - Posts: 17162 |
This study can be based upon other studies: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-18 13:42:35] |
thanks
