Date/Time: Fri, 27 Dec 2024 00:28:40 +0000
How to find a symbol
View Count: 647
[2016-03-31 08:42:04] |
User777716 - Posts: 24 |
Hi I went through your "search" and I haven't found anything The main indices like the SP500 and the DOW have subindices, how could I find them without knowing their exact names Every one does give different name to the same thing and I haven't found, for example, the "SP500 Financial subindice" Thank you Best Regards |
[2016-03-31 10:27:26] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
